bobdisk
- Nov 8, 2008
- Age
- 72
- AB IPbox 9000HD & Humax Foxsat+ HD, and about to upgrade dish, dont know what for yet!
- Near Heathrow, UK
Has anyone noticed that when a timer record is set on a channel that has more than one sound channel, for example BBC HD, (has Dolby Digital, and plain stereo) it will always record only the second channel (not Dolby Digital.) Sometimes this channel has the audio description, so you cannot turn it off if you dont want it. Sometimes the BBC SD programmes have the normal sound on the first channel, with the audio description on the second channel, so you get only the audio description. I have been unable to find any way to set which audio channel to record. Has anyone else noticed this, and found an answer? If you record manually, you can select which sound to record.
