tit card comes up with errors occure in my aston cam 1.5
P
PICKLE
Likes
can someone suggest what i`m doing wrong am getting very peed off with this, card programs okay place card in reciever and comes up with error occure with card u guys out there say u see clear light of day i`m still stuck in limbo please help me. can i update my cam or turn into a mr cam
psats
psats
Likes
not all the titanium files work on the Aston if i was you i would try another set of files
Likes
1,296
#3
Yes why not try the Wholetthedogsout file on Fookfiles.
P
PICKLE
Likes
where should i be looking for the file on fookfiles please your help is gratelly appreciated
Likes
1,296
#5
It's actually under Conax and not Seca, but it seems to work well in original Aston equipment.
N
netjunkie
Likes
i have the exact same problem / error message with a tit card and my aston cam (1.05). it worked great with another tit card i had - unfortunately my dad has it at the mo. i have tried a few files now but all come out with the same error message when i insert it in the aston cam. and this same tit card worked fine recently in my Mrev when we were waiting for 2.09. so i don't understand. and the aston cam reads the seca gold cards without errors, so i haven't worked out what is going on.
(humax 5300 vaci)
werd,
netjunkie
ps have you resolved the issue yet pickle?
N
netjunkie
Likes
no that file didn't work either. :( but again it works in MRev.
psats
psats
Likes
netjunkie said:
sorry i don't understand what you are trying to say. :(
sory if i did not put it so you can understand
with the titanium card you can have diffrent types of software inside the card ie / 103. / 106 you programe your card to suite the files / cam / rec
you use card updater ver 1.10.02 to change up or down
N
netjunkie
Likes
oh sorry dude yeah i use 1.06 for my original blue tit (that's how they came). do you suggest downgrading it to 1.03?
my dad's tit card is also 1.06 and works fine in his 1.04 aston cam.
heh. weird?
werd,
netjunkie
psats
psats
Likes
heh. weird?
werd,
netjunkie
its worth a try you can go back to the os you want
but some have probs with the procees so its up to you.
N
netjunkie
Likes
nah that didn't work either (103 and 105). maybe it's the CAM in someway? hmmm?! but it reads and works with my goldcards. hmmm?!
werd,
netjunkie
psats
psats
Likes
it is a prob that other peep have asked about on other sites so it looks like you happen to have one of the cams or card combo that dont work
N
netjunkie
Likes
thanks anyways :(
does seem like the problem should have a resolution though.
netjunkie
