Titanium Card II, USB Phoenix Smartmouse Interface
Likes
I just purchased a USB Phoenix Smartmouse Interface, and a Titanium II card, i have programmed the cart with OS 2.1, but whwn i try to load a hex file i get varius failure messages i.e. Unsupported OS or Trapping card without nothing more happends.
I have tried to dawngrade the OS, but only getteing the same errors, can anybody help me?
jimbo
Likes
Sky HD, TM6800HD, Manhattan Plaza ST550 and TM1500 CI+. 1.0m dish and 36v motor, Panasonic DVD HDD recorder and Panasonic video/DVD recorder. Sony G800 HD TV stand/surround system + Sony KDL40W2000. Infinity USB, Elvis, CAS1, CAS2.
Greater London
#2
Mickha
Likes
553
#4
Hi PHa58,
can I ask you what software programmer you are using, and also can you please supply more information on your Titanium II card as it is not a card I have heard of. I have an original Titanium card OS 1.06 and use Cardprogger 1.10.02, but I am unsure if this will suit your card.
Best wishes
Mickha
Likes
Hi Mickha
I am using Titancard Programmer v1.10 for titancards,
The card is reasently procured as Titanium II.
I am confused, i assume i must use .crd file or .s19 files, is this the same as .hex, and can .hex be converted to .crd/S19?
PHA58
Mickha
Likes
553
#6
Hi PHa58
I'm not sure you have a titanium card but a Titan card, these are two different cards, can you please describe your card.
Best wishes
Mickha
Mickha
Likes
553
#8
Hi PHa58,
I have tried to search for a titanium 2 card, but can't find it, can you please tell me where you bought it and what files they work with, I did find a Titan 2 card here:
_http://www.maxking.com/titanium.htm
There was a white Titanium card, brought out when the original Titanium cards were not available, but these worked the same as the other Titanium cards and used OS 1.03, 1.05 and 1.06.
I have searched Titaniumcard world for information on this card but can't find anything, can you please supply any further information, and information on which software programmer you use with it.
Best wishes
Mickha
Located the following web site:
_http://www.satport24.de/pd-94622336.htm
This seems to match your TC2Boot V 2.1 but I still can't find any information on which files it's compatible with or software.
Likes
HI Mickha
I think you are right about my card, even if it printed on the card "TITANIUM II", i think this is a TitanCard2, i downloaded a file from http://www.titancard2.mine.nu and they work on my programmer.
Thanks for the Help.
Best regrds
PHA58
Mickha said:
Hi PHa58,
Best wishes
Mickha
Mickha
Likes
553
#10
Hi PHa58,
thank you for telling me, somebody else on this forum is experiencing the same problem, I'll try and point him to this thread and hopefully he can program his card.
Merry Christmas
Mickha
