Total newbie question about setting up motorised dish
Rob
Rob
Technomate TMS-1500 CI+ "patched" receiver, 90cm p/f 36v motorised dish, Inverto C120 0.3db LNB, Moteck V-Box 2, Packard Bell 6052 XP Home computer, Toshiba A60 laptop, and lots of Russian Vodka !
Essex
Have a look at the sticky threads at the top of this section on how to set up a motorised dish, it's all there all you have to do is read it.
If using DiSEQc 1.2 you will need to tune in each sat, but if using USALS set up Thor and all the others fall into place, as long as your set up is 100% ok.
To select a channel just select with your remote control and the receiver will do the rest.
All you have to do now is get reading.:-doh!
S
sg_
45w-52e 80cm VU+ Duo2 (DVB-S/DVB-T)
Northern Ireland
Thanks. Was thinking of asking the same question myself on what the difference was :-ohmy
F
frund
triax 1.1 tm 1500ci+ dm patch. Moteck 2100. Intel 4300 based pc . LG7500. 32" lcd
Wales. UK.
Same here. Once you have learned something that bit is understood-ish but there always seems to be something else completely bewildering waiting in the wings.
BGonaSTICK
BGonaSTICK
Dreambox 7000, Skystar2
Brighton
Yep, and guess what... in sat-tv-world it doesn't matter how long you've been in the game, there's always going to be both grey and black areas if you go looking for them.
:-ohmy
STICK-THE-NOVICE
