Tps..help
M
macone
Likes
I can get Multivision channels but not tps cine channels. Using index 09 hex keys for TPS so I'm wondering how I can get some channels and not others if the same keys are used for all the providers channels...or are they? what can i do to get these cine channels please.
Using technomate 5500 and manually input keys through remote.
any help greatly appreciated.(Worked in UK 2 months ago but now living spain,dont know if that makes a difference)
S
satboyuk
Likes
i exprienced this problem before but what u need to do is check you typed the codes correct and also do not type the code index e hex.type all until d and do you have the latest keys forthe tps because tht is also one important thing.
hope i helped
S
scrambler
Likes
I had the same problem. You can either delete one of the "d" whichever is older or delte the whole set of keys and input them again. MAke sure you write them down somewhere. On the other hand make sure also that you only have ONE "d" key
M
macone
Likes
hope i helped
thanks satboy. A combination of you and scramblers idea did the trick. I took out e hex and then retyped everything back in and it worked. thanks to you both.
N
newbie123
Likes
this was great advice guys,m i deleted all te keys and re-entered, now i have tps star and sat footy, cheers - come on villa
M
macone
Likes
newbie, what channels the footie on / whats star?
macone
N
newbie123
Likes
macone
hi there, there is sat footy on tps star, yesterday it was fulham-liverpool. on multivision they had a few games arsenal-villa and city-chelsea but i didnt watch those.
multivision has a specialist channel that shows footy on it, it also repeats games in full too, i think all the weekends prem games, correct me if im wrong. if you have any probs getting it get back to me, pompey-spurs 2mrw, come on lily whites..
N
newbie123
Likes
sorry, tps star is part of the whole tps package that includes the film channels and other entertainment channels.
alfin
Likes
Until the beginning of Sept. I received TPS package without any problems. Then reception went on the 'edge' - the picture kept breaking up. In the last 2/3 weeks, I get 'no signal' indicated. Multivision reception is ok.
Location is NW England.
Can anyone confirm that it is still possible to receive TPS in this area?
Thank you.
afro_king
Likes
I need some help, gentlemen. How can I enter codes on GulfStar receiver model, GS9700S1? Your help will be appreciate
afro_king
Likes
I need another help, gentlemen. How can I enter code on echostar 2110 model
