TPS 'no signal'
alfin
Likes
This may have got lost in a previous thread; apologies if you have already read this.
Until the beginning of Sept. I received TPS package without any problems. Then reception went on the 'edge' - the picture kept breaking up. In the last 2/3 weeks, I get 'no signal' indicated. Multivision reception is ok.
Location is NW England.
Can anyone confirm that it is still possible to receive TPS in NW England?
Thank you
BGonaSTICK
BGonaSTICK
Likes
Dreambox 7000, Skystar2
Brighton
#3
stef2 said:
i have a problem I get all the tps channels but no sound, WHY?
Please don't thread-jack so blatently. Please start another thread.
Thanks.
Razor
Razor
Retired Mod
Likes
Ireland
#4
Thank you
Should be a strong signal in the UK, what size dish have, hell tell us all, dish, receiver, cams and cards.
alfin
Likes
90cm dish motorised; technomate TM5500CI Super; Dragon Cam; no cards
Razor
Razor
Retired Mod
Likes
Ireland
#6
90cm is more than enough, there was a key change a while back maybe you just need to input new keys into your dragon cam. At the moment I get TPS and MV with a fun card. Might be worth buying one. A Fun6 will cost about £8 to £12 and are very handy to have. With just a fun card and a simple Via 1 file you can get 7 or 8 providers.
alfin
Likes
Thanks for the reply. If it was simply a key problem I would still get a signal with an indication 'scrambled'. Now I know I should I should be able to receive TPS, I think I have a problem with my setup. Highlighted last night when in the very poor weather conditions channels were dropping out on several satellites and those I could receive the signal quality was low.
LNB or dish alignment?
alfin
Likes
Razor said:
Both ?......
Problem solved, now getting TPS.
Had the dish realigned.
The signal quality meter on the technomate for multivision is close to 100;
for TPS it is on 50.
