Triax 2140 prime focus aluminium antenna w. polar mount
archive10
My latest project:
I acquired this dish in spring 2016, specifically to use it for C-band as a "micro-bud".
1.2 meter offset dishes are nice, but while being only marginally larger visually, a 1.4 PF dish is 36% larger area-wise than a 120cm - could make a real difference with C-band.
Seller said it was mounted on a house he had just bought, and he just wanted to get rid of it.
Feed-arms are visibly bent, looks like handling damage. Should be ok with a little twisting.
There is evidence of some slight bending and scuffs on the edge of the dish here and there.
But the surface seems generally ok too.
I strung the dish to check for any warping, and it seems to be in very good shape.
The dish came with a nice sturdy wall mount, which I wanted for other projects to begin with.
The polar mount, unusually, included it's own, welded-on bit of 60mm pipe.
This fits right into the wall mount, but is not directly compatible with anyhting else I have.
Two apparent challenges with the dish:
1) Feed-holder was originally for small bore feedhorn, now somewhat crudely butchered to accept 40mm LNB.
2) Polar mount with the 60mm tube is not easily mountable on normal mounts.
Unfortunately, the original feed-horn was not supplied with the dish.
Instead it came with old universal Ku-band LNB strapped on with a cable tie.
I am curious to see how much signal is lost from the f/D mistmatch if I compare a universal with a PF LNB...
The polar mount is steel-plate rivetted job, and has nylon/plastic bushings.
Metalwork is galvanised then powder coated.
Channel Hopper thinks it's a Lenson Heath mount - perhaps the dish is a Lenson Heath thing too?
There was no actuator - only a metal rod for manual installation.
The plan now is to set-up and align dish with Ku in a test configuration, to get my bearings.
Then I will swap the feed for a C-band one and see what I can find.
Later options include permanent mounting on wall, and multi-feed options.
st1,
That's a very nice looking dish and has cleaned up well. I hope you get some good catches on C band with it.
Rgds
RimaNTSS
Some SAT-related hardware.
N-E from Riga
Sten! Nice dish and interesting project! If you wish, this holder is yours IMG_20170528_091032 (Medium).jpg IMG_20170528_091039 (Medium).jpg
I think, I also could help you with new feedarms.
Could you show couple of close pictures from both sides of the dish how the feedarm is connected to it? ScreenHunter_320 May. 28 09.20.jpg
archive10
Sten! Nice dish and interesting project! If you wish, this holder is yours View attachment 107343 View attachment 107344
Could you show couple of close pictures from both sides of the dish how the feedarm is connected to it? View attachment 107345
That's very kind of you - I will be happy to try the LNB holder.
I'll go and take some more photos later today.
First I need to put all this stuff back in the outhouse, as the cold front is approaching and will be here in about an hour... :eek:
RimaNTSS
N-E from Riga
@st1 I think you will be happy about performance of the holder, as it can grab anything (which is round and proper diameter) and hold it tight but gently. :-rofl2
archive10
Here's a few close-ups of the feed-arm ends, both dish-end and feed-holder-end.
The arms are 685 mm long. But I think the original feed-horn is quite long, so that the focal point of the dish is quite a distance in front of the original feed holder (see picture).
I was considering just using a triple of threaded rods as feed-arms. This will allow quite a good range of adjustment.
But on the other hand - I am wondering if the threads on the rods actually make them induce more noise in the reflected signals than smooth arms...
Incidentally, I found this installation diagram of the Triax 2140 - nicely hand-drawn, and showing the analogue heritage...
IMAG4088x.jpg IMAG4089x.jpg IMAG4090x.jpg IMAG4091x_2.jpg IMAG4092x.jpg IMAG4093x.jpg Triax_2140_PF_feed.jpg triaxsystem.gif
RimaNTSS
N-E from Riga
Nice pictures @st1 , thanks. What is the diameter of the pipes? And I suppose the bolts fixing pipes to the dish are M8. So, if you have a ne feedarms they could be 685mm and extendable another 100-150mm..... would that be enough?
archive10
Just went and measured - they're 12mm arms. They feel like aluminium.
I think new arms should be shorter; perhaps 570 mm or so, to allow for some adjustment room for both C-band a long-neck Ku-band LNBs.
And who knows - maybe it will do Ka-band as well; it does seems very well made...
RimaNTSS
N-E from Riga
@st1 Feedarms for your antenna are ready. In case if you wish to use Ku-band LNB, there is also 63mm/40mm adapter in the set. And several 40mm wooden (oak) cylinders to hold laser-pointer. Unfortunately I just broke couple laser-pointers, but, I think you can find one locally, not a big deal. ;) But, mind you, laser-pointers are far from perfect, their body not always parallel to the beam they make. So, it is advisable to calibrate pointer in the cylinder. INOX thread like to be greased ..... I use copper grease for all nuts&bolts, so they never stuck together.
marciano
powerpack 1.20m
brasil
do you fantastic !
Nice work and a very kind gesture.
Rgds
archive10
Some Christmas presents arrived 7 months early...
Feels like excellent quality - and wrapped contemporarily as well.
Unfortunately, I will have to wait until the weekend (possibly later) for mounting, due to chores things like "work" and "family".
Thanks, @RimaNTSS!
archive10
Finally got some dish time this evening.
I wanted to fit new feed-arms on the 2140 to be able to mount the C-band LNB.
First, I needed to remove the original, but somewhat bent, feed-arms from the dish.
Based on bitter learnings of rusting machine bolts, I applied multiple serving of WD-40 to the bolts, but they were still very tight.
Was fearing that the bolts had rusted solid in the threads.
As it turned out, that was not actually necessary...
When I finally got the bolts to move, they turned out not to be machine bolts, but hex-cap screws!
Arms are just pieces of 12mm diameter alu-tubes.
The arms have no thread inside, instead Triax used rawl-plugs that fit snugly in the tube.
Carefully set aside the stand-offs that support the angle of the arms wrsp to the dish surface.
Removed the arms, and dug out the nice INOX-set of arms that @RimaNTSS so kindly manufactured to handle the C-band LNB holder.
Darned!
Much to my discontent, the holes in the dish turns out NOT to be for M8 bolts (as integrated in the RimaNTSS design), but for 5mm screws as in the Triax design.
Maybe not so big a problem, I have a 9mm metal drill.
But I cannot use the stand-offs any more.
GRRR.
SO - the question is: What do I do now?
Do I drill out the holes in the dish to take M8 bolts, and attempt to make new stand-offs (eg through 3D printing)?
Or should I try to find some sort of adapter from M6 to M8 (Meccano-pieces come to mind), and re-use the old stand-offs?
Or is there a simpler way?
RimaNTSS
N-E from Riga
Sten! Just drill bigger holes in the dish and also in the adapters shown on picture #4 in your post.
archive10
Yes, but the adapters are made of rubber, which by now has turned to brittle, hard stuff.
I'm afraid drilling will vapourise them.
I think I will try find some sort of plastic or rubber tube that can be made into new stand-offs...
Or even wood, perhaps? Suitably dipped in varnish or something??
archive10
Took some time out in the winter cold today and sorted out the 2140.
First put the mount on the test-bench, and levelled it.
Then drilled out the holes for the new feed-arms in the reflector.
(After visiting hardware store for a new metal-drill...)
Then semi-fitted the new feed-arms so kindly provided by @RimaNTSS.
They work well, but
a) the "ears" on the feed-holder needs adjustment, and
b) they are really shoddily attached to the dish.
So, in the near future, some more work needs to be done to the system.
Then, to get some picture, I slapped the dish back on the mount (after sunset, so some dodgy flash-photography is evident).
The mount has BTW been treated in the past couple of days.
Disassembly, the lubrication of plastic/nylon parts with Silicone Gel.
Then re-assembly - and everything seems to be working nicely.
The dish is now up again in the manual adjustment configuration.
Next up (when the weather improves): Proper feed adjustment.
(Right now it's pretty much slapped on!)
archive10
Day-time possibilities for tweaking.
First-up: Checking the placement of the LNB.
To eliminate any irregularities from a badly aligned polar mount, point dish at 13E (which is almost due south here).
New feed-arms adjusted to replicate old feed-arms (same ~60cm distance from dish face to holder).
Then check the in-out placement of the GI prime focus LNB.
As with the old feed-arms, best reception is when LNB is as close to dish face as possible.
(and also not a very impressive result in terms of strength and quality!)
This seems to indicate that the feed-horn opening might benefit from being even closer to the dish face.
That'll be next steps.
But just to experiment, I slapped on an Inverto BUQ with it's 0.6 f/D feed-horn.
Amanzingly, the performance is better than the GI!
And it too performs the best when pressed as far as possible into the feed-holder.
(But it does look weird - having a high-performance offset LNB looking at a PF dish for best performance!)
To get the LNB closer to the dish face, I will have to redrill the feed-arm holes in the dish, and bend the LNB holder somewhat. But it was inevitable.
What do you think - will the performance improve? Will a properly-positioned GI overtake the IBUQ??
Even though they have about the same distance-to-the-front?
RustySpoons
Sleepy Hollow
50E - 30W
2x CM 1.2m Polar Mount/Jack
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
Looking amazing, love that dish and your work, RimaNTSS's bits look fantastic!
What vintage is that dish, I haven't seen that logo for a while.
Talking on Inox, I was helping my friend earlier who's moved house, I unpacked a new set of cutlery for her that she bought and they looked incredible, a really nice colour. Turns out they are Inox, I have never seen this before :)
