two lnb help
P
pringle22a
sattelite setup-
Dreambox 500s
Dreambox 7020s
2 X maximum 4 in disecq switches
1 triax78 dish on hotbird 13e
1 televes 60cm on hipasat 30w
1 minidish on astra 19.2e
cabling is all webro wf100 coaxial
computer setup-
amd athlon dual core
NW LONDON
hi everyone,
i need some help with my installation, i have just installed a fixed 80 cm triax dish receiving hotbird on 13e. i was wondering is it possible to put another lnb to receive a different sattellite. If yes would i have slightly move the dish with an additional lnb or no.
could someone please help me.
thanx.
2cvbloke
2cvbloke
Bulbs need shelter too...
Near Pontop Pike, Co. Durham
pringle22a said:
hi everyone,
thanx.
You shouldn't need to move your dish at all depending on which satellites your after, just add a multi-LNB holder onto one side of your current LNB (for example, ~6 degrees to the left (looking from the front) and slightly higher to get Astra 1 at 19.2E), or if you're after more than two or three satellites, it's best to start a dish farm (unless the missus objects!!!) or motorise your current dish.... :)
You want the Triax TD-Flexiblock or the TD-Duoblock 6 degree bracket, they replaces the LNB holder on the TD dish and the LNBs sit either side of the centre. Pictures Here
D
d122k7trb
Judas Priest
IClass Receiver
2 Premium X LNBs Hotbird+ Nilesat
120" Dish
Computer system:
AMD Phenom Quad quad core 9750
4GB DDR2 Bus 800 RAM
MB: Asus Crosshair
1 TB Seagate Barracuda 32 MB cache
22" LCD Widescreen Samsung 226BW
SB X-Fi Xtreme
Armenia, ME: The Arab Countries
Depending on your installation and the post where you've placed or set your dish, if you have a shortage of place for setting another dish, you can use a motorized dish instead of 2 or 3 dishes. In my point of view it could be also economical. Or there are also 2 different turnip-like dishes attached to each other but in 2 different directions.
Arbi.
