urent!!! help!! two lnb on one dish
Likes
fixed dish
westmidlands
#1
ok I have been trying get this sorted all day but no luck the problem is
I have 1meter dish pointing on arabsat 26degree east digtal is working fine
so I bought a twin lnb holder same as this one
so i was able to pickup astra 19 degree east using another lnb placed on the lnb
holder apart from that am unable to get anyting else I need to point it at hotbird but
is not seems to pick it up so did anyone of guys managed to get both Hotbird 13° East
Arabsat 26 East on a single dish if yes can you please explain how to do this that will help alot
Topper
Amo Amas Amant Admin
Likes
3,272
IDD CI24 ECONO MM Penta 1.20 Galaxy II
1.2Mtr Polar MTG yes it has been on the arc for 25 years and is now fixed on 13 East using two pairs of rusty molegrips. Unlike me they never groan but always perform.
Blackburn, Lancashire
#2
So which is the lnb that is picking up 26E is it fitted on the right in the picture?. How are you connecting your 2nd lnb? to the stb?
What elevation have you introduced on the 2nd lnb?, it should not be horizontal with the other
Likes
1,279
#3
That holder should do it, 19E will be about halfway there, is there enough left on the bracket to slide out for 13 E?
Likes
fixed dish
westmidlands
#4
the lnb that is picking arabsat is already fixed to the dish so am trying to pickup hotbird using the lnb holder by adding one lnb while my dish currently
pointing on arabsat am using a DiSEqC switch to link the two lnb to the reciever however am unble to get hotbird on the other lnb i was able to get
astra but not hotbird so am i doing samthing wrong here
Likes
fixed dish
westmidlands
#5
rolfw said:
That hpolder should do it, 19E will be about halfway there, is there enough left on the bracket to slide out for 13 E?
yes there is which way do i move it left are right i was able to get astra by moving it left
am thinking of buying a satellite meter
Topper
Likes
3,272
#6
I do not think so, you just need to move the lnb further towards the end of the bracket as Rolf says i.e. further away from the primary lnb
Likes
1,279
#7
You move it further away, by about the same again.
PS. You will also need to bend the bracket downwards slightly to allow for the difference in elevation of the satellites.
Likes
fixed dish
westmidlands
#8
yes I already did may be the lnb need to be moved up and down but it does
no let you do that which satellite meter is good for digital
Likes
1,279
#9
You move it down by bending the bracket.
Likes
fixed dish
westmidlands
#10
I will try that tomorrow if it does not work I will just install another dish
and use it for hotbird
jimbo
Likes
Sky HD, TM6800HD, Manhattan Plaza ST550 and TM1500 CI+. 1.0m dish and 36v motor, Panasonic DVD HDD recorder and Panasonic video/DVD recorder. Sony G800 HD TV stand/surround system + Sony KDL40W2000. Infinity USB, Elvis, CAS1, CAS2.
Greater London
#12
Hasn't done the lawn much good. :D
Likes
1,279
#13
Ameen, please don't link to images, use the manage attachments facility and upload them.
