djc said:
Managed to store Hotbird on number 30. To do this I selected number 2 from the table (even though number 2 relates to Astra19.2) and then fine tuned it, then stored it.
Have tried several others against the table in the SG2100 book, although the dish seems to be going the right way, its getting no signal. Is there a way I can manual tune all of them like I did with Hotbird ? Obviously to add the channels into the Sat list (on the right hand side of MT) you have to have scanned succesfully, you get my point ? So would like to be able to tune to a say Hispasat Channel, then fine tuning by stepping East/West ?
BTW, don't have Hispasat in the Satellite lists in the Plugin for some reason. Might have something to do with that I imported 139 .ini files, yet can only see 30.
Cheers
I'll get there in the end you know
Firstly, enter the positive figure for your longitude, i.e. 358.3 or whatever it is where you are. Also select the motor type as SG2100.
Good, seems like you have Hotbird pretty well sorted and stored in the motor (although you don't have to store sat-locations in the motor, you can just store them in the plugin using the 'Modify' button). When you switch to a Hotbird channel in MT, it will automatically drive to that sat.
Right, now drive your dish to Hotbird, and then press the 'Auto Goto x.x' button. This will re-align all the other specified satellite locations BASED ON WHERE YOU HAVE TOLD IT THAT HOTBIRD ACTUALLY IS. You'll still have some minor fiddling to do for each sat, by stepping east and west etc. Don't forget to click the 'Modify' button for each one, so that it will remember it for next time (and store it in the motor as well if you want.)
Hispasat 30W should be there, but don't forget, it will be down the bottom of the list at 330E!!!
Here is a summary/recap of what you should do to tune/scan a sat in MT.
Get the list of transponders correct for a given sat (either import, manually update, or re-key them from Lyngsat etc.)
Allocate to the sat, an LNB on the sat/transponder setup page. Also set to Ku band and save.
Manually align the dish using goto x.x (or goto angular position as it says on the plugin) and then max the signal by stepping east and west slightly.
Then do the Max Signal button thing, and the plugin will fine tune the dish. If it says 'Signal to week' try again, or step slightly east or west and try again.
You need to get this to work to optimise your dish alignment.
Save the sat location in the plugin using the 'Modify' button. Store it in the motor using the 'Store Satellite Position' option in the diseqc drop-down listbox. Then go back to MT, go into setup, select all transponders for that satellite, and perform a scan.
Once you have it all sorted, back up your MyTheatre folder (in the Windows Program Files directory) to somewhere else.
STICK
