Hi pips,
Can anyone help ?, have just installed a technomate TM-1000D with a StabHH motor and a 60 CM dish and I am trying to configure USALS using Thor 1.0W but I don't know what position setting I should enter ? (for W and N),I am located in central London,
Thank you for the quick reply, but can I assume that because my dish is only a bog standard 60cm sky dish I wont be able to get a good signal for 1.0w (transponder 11.189V) to use as a reference for USALS ??
No, don't use 5W, if you are in central London, then you are going to be at 0 degrees or thereabouts, so 1W will be your closest satellite to due South.
Best to look for BBC World on 11325H, 24500, 7/8. With your dish size and location you should easily get a lock on that transponder.
As rolfw states, 5west is too far off of your south satellite, which for London is 1 west. PR
