Use old analogue sky dish & cable for digital ?
Likes
Freeview Terrestrial & old analogue sky.
Amd 2600m@2500mhz, 1gig ram, 6800 vga, Abit NF7S v.2.0
Suffolk
#1
Hello all, i currently have an indoor aerial for freeview T & average reception. I also have an old sky analogue dish on the side of the house which still picks up cnn & german channels, i'd rather buy a digital reciever & lnb( monoblock if poss ) and use the old dish ( think its a 60cm mesh ) than put up an outdoor aerial. Question is, will that work with the dish & cable already installed, or would i have to change anything ?
I know bugger all about these things but think i'll get more for the money than simply upgrading the aerial. Thanks in advance for any help & advice.
gameboy
Ding Dang Doo
Likes
5
Scotland
#2
:-Welcome1
The dish is pointing at the wrong satellite for S*y digital - but would be simply to move. Check the bolts are OK and you can move to the new position, left of the present direction (from back of dish) check other dishes in your area.
The part that points at the dish LNB may need changed but that's not expensive. The cable should be OK.
Why bother when S*y will install free?
Likes
Suffolk
#3
I'm not looking to get sky digital/freeview channels, but digital channels from 19.2 ( same as analogue position ? ) & 13.2 if possible. I'll stick to the terrestrial box for the rest.
gameboy
Ding Dang Doo
Likes
5
Scotland
#4
Dish and cable would be OK the LNB may need changing - best try a Freeview satellite receiver on the dish and check. Beg or borrow one until Lidl get them back in!
Your present LNB frequencies may not cover all the available channels.
You can check the free digital one on Lyngsat web site - here...
_http://www.lyngsat.com/astra19.html
Likes
Technomate 1500CI+
85cm motorised dish
Freeview
Nr Manchester, UK
#5
I have done this with an 80 cm channel master dish and a technomate 5500d with monoblock. No problem whatsoever. Now all I need to do is to patch the technomate....
Likes
Suffolk
#6
I'll give it a go me thinks, just the lnb & reciever it is then.
wod
Likes
235
yorkshire
#7
i'd suggest replacing the cable aswell as the lnb
Yeshi
Likes
Dm500, TM9100, Samsung V+, 1M Dish. Motect 2100..
37Inch Plasma, Wii, Xbox360.
Behind pin 9 on an atmel
#8
Why? when its reciving channels already, dont fix what isnt broke.
Another thing with the old sky dishes the u bolts tend to be a little fragile. as theyre very old now..so if your going to adjust be careful.
also i suggest getting a technomate 1500ci :)
Likes
Suffolk
#9
I've had a wee look & alot of people seems to like the technomate, will have to search around for a good price ( tight budget or tight arse, take your pick:) )
Likes
Suffolk
#10
Have ordered the Technomate TM-1500 CI+ Super & a monoblock lnb, now just a matter of time:)
wod
Likes
235
yorkshire
#11
excellent choice, once its installed , patch the reciever for some more channels
Likes
Suffolk
#12
I've just measured the dish & its 66cm horizontal & 76cm vertical, is that going to work witha monoblock ? & 2nd Q. its set up for 19.2e, when fitting the new lnb will i need to move the dish or rotate the lnb to get hotbird as well ?.
Yeshi
Likes
#13
Leave the dish where it is.. it will be fine. remeber hotbird will be to the right of 19.2..
Likes
Suffolk
#14
Okay, just put the lnb on horizontal ( flat ) and hopefully good to go. Huge thanks to everbody by the way, hoping to make this as painless as possible.
Likes
Suffolk
#15
Gear arrived this morning, have flashed/patched the Technomate & fitted the lnb, which was a pain in the arse ( super mega rusty screws & bolts ). Ended up losing astra so decided to do it as most people would & use hotbird as the main one. Okay, so far i've got hotbirds quality level blipping between 60 odd % & 0 whilst astra's solid at 72-5 %. Seeing as the dish was pointing at astra to start with do i need to elavate the dish to strengthen hotbirds signal, then rotate the lnb for astra ? if so, by about how much ?
Oooohh, i've got astra 28.2 as well @ 70% currently watching itv 1 in artifact free vision( whilst i wait on details for the above) which is something i could very rarely do on terrestrial:)
Likes
1,287
#16
Yes, elevate the dish and the rotaion shoiuld be only a few degrees, akin to the amount of skew required. :)
Likes
Suffolk
#17
I'll do it after qualifying, this is just fantastic stuff ! didn't think i'd get most of the freeview tv as well. If i get men & motors back i'll be sooooooo happy, i've been missing my weekly slot of build or bust.
Likes
Suffolk
#18
Well i pressed on & the best i can get for hotbird is that fluctuating quality signal 0-60ish%, changing the elavation only weakens that signal. there is a house & tree ( quite large ) across the street & the dish itself is mounted on the east side of the bungalow(only place). Either of these could be the problem, both astra sats are coming in strong though, so for now i'm pleased.
Likes
Suffolk
#19
Think i need a bit help, although 19.2 is showing 75% quality no programs are viewable ? just get a no/bad signal message on every channel. Only 28.2 works, is the reciever showing the same signal for both astra sats ?.
Likes
Suffolk
#20
Just tried the old analogue reciever again & on lnb B its still picking up eurosport, cnn etc... with a few sparklies though.
