Using an old dish for double LNB
Gamboa5000
Nextwave S311
When I had an analogic decoder, I had a dish with a diameter of 120 cm. Now I have buy a DVB compatible decoder and a new dish but whose diameter is only 80 cm.
I want to receipt the super beam.
The old dish is rusted,did they affect the quality of receiption?
Can I use the old dish with double LNB 0.4 dB?
Thanks.
If your dish is rusty, then I assume that the rust can be cleaned off and the dish re-painted if necessary. You can fit a twin LNb to any dish, or do you mean a monobloc (looking at two satellites)?
We need to know where you are and which satellite you want to look at, I am guessing that you mean Hotbird, but not sure.
Gamboa5000
Nextwave S311
Excuse me for my late answer. I speak about double LNB on a old dish 120 cm who was useful by a mono lnb and analogic decoder.
For seeing Hotbird 13°E and Eutelsat W2 16°E.
I hoped to have better a reception with the old dish.
Thanks.
If you fill your location in correctly in your profile, we could help better:
Gamboa5000
My System: Nextwave S311
is not terribly helpful.
