flyinhaggis
- Jan 24, 2005
- Website
- www.freewebs.com
- Scotland
Ok it's against the law to defraud sky but if you were goin to do it youd probbly have to have yer 2nd set top box connected to the same telephone line but then in theory your digibox only call's back to sky once a month if you knew when that was you could plug it in and let it do it then put it back but theres always the problem of if you ever have any billing problems or the likes they can do a callback from their end whenever they like
if you want to do a call back it's easy press services then option 4 systems set up then ignore options on screen press 0 then 1 then select it opens installer set up then either add 1470 prefix or do new installation and voila it calls back to sky
the only reason it does this is so cant rip em off for box office movies with the battery thing llf
