visioplus dtv sat 1020a need help
manc
HI,
AFTER LOADING DBVDREAM 0.8.5 geting message stating
"DVBCORR.DLL file is linked to missing export.SETUPAPLI.DLL.CM_GET_DEVICE_IDA"
USING WINDOW SECOND EDITION IN MY COMPULER AND ALREADY INSTALLED VISIONPLUS DTV SAT 1020A.
PLS HELP.
miro100
manc said:
HI,
PLS HELP.
hi
DVB dream is greate software and very easy to use but u must install it in WinXP it not working in windows 98 any edition
Have nice seeing :)
manc
miro100 said:
hi
Have nice seeing :)
hi
thanks, i installed winxp as well as directx9 but get the following error satating as:
Cannot Initialize DirectShow. ErrorCode:20
Try these for solution:
-change graph that must be compatible with installed code
-Install codes again
-Install directx9 or newer version
pls help how to change in details? and from where i can get correct graph codes.
thanks in advance
miro100
manc said:
hi
thanks in advance
Hi
for mpeg2 codecs search internet for this file " mpeg2_decoders.v2.02.exe " then install it first then download the new release of DreamDVB 0.8.6 from www.dvbdream.org and instal it in new directory ex., " C:\DVBDream86 " and run this software this is the best solution as i don't know what is your configration. and have a nice seeing.
by the way there are no problem if you delete the first dvbdream installation directory
manc
miro100 said:
Hi
Hi
Thanks. I donot know how its happened, I having powerdvd cd. Anyhow, now i can watch fta channels.
Is possible to watch pay channels? If yes, what type of file/s needed and from whare I can downloand and how to patch/instal in my dvbdream 0.8.6, Pls help.
Thanks again.
