Help Required - wanted - hughesnet 18ghz broadband odu circular feedhorn for motorised project.
As title, - for sale or gift for project ....
Looking for the circular type 18GHz feedhorn from off the Hughesnet Broadband 'turtles'. Oval type shown in picture.
I may have one, let me check
You might be thinking of the one i had off you about a year ago praps ehh ?. Have a rummage though.
I have one, but it has been butchered, feedhorn intact but the waveguide has been cut through. Any good?
Ok - - could be re- butchered here, ie i have an unbutchered Oval one so i could do a bit of grafting the two bits together. Would you be a doll and take a picture of the one you have please :Y
Here you go dear....Think you could possibly marry it up using this 15mm compression fitting used for plumbing, which is attached to mine..P1010015.JPG
Here you go dear....Think you could possibly marry it up using this 15mm compression fitting used for plumbing, which is attached to mine..View attachment 123688
Yah i could do something with that i think squire - can i borrow it then for a while to try on me little project. If you can send it in a jiffy bag when you can and let me know the cost i'll cross your palm via paypal or summat :Y
That's a big 10-4....
