• This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn more.
what does 7+info+default mean ?
Likes
dreambox 700, head 500
germany
#1
hello,
what means "7" + "info" and default?
my receiver head 500 keyfly don´t open d+!
what can i do?
thanks!
portas
Likes
[email protected] Hispasat
portugal
#2
First, the firmware above is just for [email protected] 500 FTA or premium, you must look for the [email protected] keyfly firm.
I think that when you refer " D+ don´t open", mybeit was because you didn´t put the correct key.
After you install the correct firmw, you need to install an updated key
enjoy
look for the firmw here _http://www.sathelp.info/upload/index.php
sophia
Likes
hispasat, head500
Grande Lisboa
#3
portas said:
hello,
what can i do?
thanks!
portas
enjoy
Hi portas,
When you do 7 + info + default , you are forcing the receiver to accept the keys in the firmware that is loaded in the receiver.
For your receiver, the last firmware is here (from Pogy):
_http://www.sendspace.com/file/o4n8hv
And just like lneves mentioned what is missing is the update of D+ keys, because they are changing twice a day.
So after loading the firmware and doing 7+info+default, load the updated softcam , that was posted by Poison in the Softcam topic.
If you need further help then let us know.
PS: These posts have been moved from the Firwares topic.
Likes
germany
#4
hello,
thanks, i have the new firmware on my receiver, but i don´t know what button is the "default" one when i should press "7+info+default"?
thanks
portas
Poison
Likes
بلدي اميرة القلب
#5
portas said:
hello,
thanks
portas
The default button is the RED
Regards
