which colour wire goes where on motor
<sammy>
Likes
my setup: echostar D2510ip viaccess receiver
1 meter solid dish
silent gold 99 motor
I just purchased a JAEGER SILENT GOLD 99G H to H 36 VOLT mount.
Can anyone tell me which colour wire goes where,on motor & receiver.
{reed sensor type}....motor.. as it says you can blow the sensor if wired wrong.
i have 4 wires:
red - thick
green - thick
black - thin
white - thin
1 -
sensor
2 -
MOTOR (REED SENSOR TYPE)
3 -
motor
4 -
M1 M2 MPULSE
BACK OF RECEIVER
+5V GND SKEW
I'm going to try and install it this weekend, as i can`t find a installer
in my area... only sky..
many thanks <sammy>.
Likes
3,403
1 meter solid dish
i have 4 wires:
red - thick
green - thick
black - thin
white - thin
1 -
sensor
2 -
3 -
motor
4 -
M1 M2 MPULSE
BACK OF RECEIVER
+5V GND SKEW
Hi sammy
The thick wires (red and green) will be for the motor, and will go to the Echostar's M1 and M2 terminals. Switch these terminals if the motor goes in the wrong direction.
The thin (sensor) wires go to MPULSE (white) and GND (black).
Likes
3,403
I might add that there's no hard and fast rule regarding the sense of the M1/M2 connections - it depends on the particular motor/receiver combination. If someone has the same setup as you, they may be able to tell you the exact connection.
