Advice Needed Which E2 receiver for best tuner sensitivity?
Pierangelo
150 cm from 80 east to 40 west + C lnb
Italy
Zap news?
What's
Please
I built OpenViX today with T2MI patch.
Good work, will this version be released on the OpenVIX download site or is it an experimental version and not available for user download?
Good evening Huevos.
Is it already available in tonight's update?
5.2.019.008 (experimental)View attachment 121231
Be careful Stephen..there was an update last night but my box would not get past booting after downloading it. I assume Heuvos has now fixed that...
Yes, I broke it. That is one of the downsides of using an experimental image.
@moonbase, what receiver are you using?
@scopus, can you get me another stream recording from 40 east. Limited to around 50MB.
Also can you get me a stream recording from 4000L on 40 west, please.
I think Stephen will need to do that, he has the PC card to do it I think
Huevos,
My E2 receiver is a Nino Pro, currently running OpenVIX. However, I also have other non E2 receivers available.
What type of stream recording do you need, is it a full TS recording of all PID's in the stream? Also, how long duration for recording do you need?
About 50mb he wants
About 50mb he wants
Does he need all of the PID's in the stream or is it just the video PID? I can split the stream into the separate PID's and selectively record the required one(s). This can reduce the file size.
I have sent you a link by PM to a MEGA download of the recording you requested.
