I see from Nikolai's Sticky above that MM works with official cards for seca2, Irdeto2 and viaccess2 but when these are eventually cracked will the MM work with these version2 encryptions using for example a fun card.
nobody knows the answer to your question, as it is too early to get concerned about. I foresee, that once these systems are hacked there will be a fun card solution.
Many thnings will depend on how it will be implemented, which is currently unknown.
Will the current magic module software support it? Let us worry about this later. ;)
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
