Wireless Info
4dbennett
lifes not a practice run
Likes
SPIDERBOX 9000HD, 1.2 and Humax Foxsat HD,Hitachi L500HDD
Acer Aspire 5315 Lappy
torfaen south wales
#1
Hi all, i have talk talk broadband connected via an adsl modem, what equipment would i need to go wireless, and how do i set it up,
thanks in anticipation
deep joy dave:confused:confused
2cvbloke
Bulbs need shelter too...
Likes
1,707
Near Pontop Pike, Co. Durham
#2
An ADSL wireless modem router and a wireless adaptor in each computer that you want to be wireless... :)
I haven't a clue how to set up the ADSL side but the wireless is easy as pie, just don't forget to set up the security (WEP) on your router!!! :D
4dbennett
Likes
torfaen south wales
#3
Will any brand of router do the job??, i assume the adaptor goes in the usb port ??? does the adaptor have to be the same brand/type as the router????
thanks m8
deep joy:-doh!
dave
2cvbloke
Likes
1,707
#4
thanks m8
deep joy:-doh!
dave
Most will do, but it depends on what speeds your after, a cheap 11g router will do up to 54Mbps whereas, for example, a Netgear router with the right feature (I forget what it's called) can do double that, and if it has MIMO I think doubles that again... :)
As for the adaptors, if it's a laptop you have 3 options, you can use a USB adaptor, a PCMCIA card or (if your laptop is equipped with internal antennas for this) an internal Mini-PCI card... :)
A PC though has USB and PCI card options only... :)
mhku
Likes
20
TM Nano ~ sg2100
Midlands
#5
You may be able to plug a wireless router into the existing ADSL modem if it has an RJ45 socket.
4dbennett
Likes
torfaen south wales
#6
Thanks mhku and 2cvbloke, your info is very welcome, i,m a complete novice at this and most sales people you speak to only seem to confuse the issue with technical terms and sales patter,
thanks again.
deep joy
dave
2cvbloke
Likes
1,707
#7
thanks again.
deep joy
dave
Computer stuff is pretty easy, it's just sales people in big chainstores that make it seem impossible... :D
PoloMint
Super Minty Mod
Likes
1200cc with 100,000,000,000 neurons and 100,000,000,000,000 connections
Fife, Scotland
#8
Is your modem USB at the moment 4dbennett? If so you will need to replace it with a router as described. The SpeedTouch 585v6 is one of many excellent choices for home use.
2cvbloke said:
...the wireless is easy as pie, just don't forget to set up the security (WEP) on your router!!! :D
Yes, but if all your hardware supports it then set up WPA instead :D Apart from that all you should have to do is enter your ADSL details.
2cvbloke
Likes
1,707
#9
I'm sure I remember reading something that said that WPA was easy to break open with the right software... :confused
Or was it WEP?:confused
PoloMint
Super Minty Mod
Likes
Fife, Scotland
#10
Probably WEP - while WPA may not be completely secure (doubtful that anything wireless would be) it is generally considered to be much better than WEP :)
Likes
1,286
#11
You can always use WEP with MAC filtering, then it will only allow previously arranged PCs.
2cvbloke
Likes
1,707
#12
That's what I read!!! WEP & MAC filtering!!! :D
PoloMint
Super Minty Mod
Likes
Fife, Scotland
#13
Yea MAC filtering is a good idea with WPA or WEP (or even if the network has no encryption) as is hiding the SSID.
But MAC filtering and hidden SSID often give a false sense of security. Cloning a MAC is not hard, and if someone has grabbed enough info to break the WEP then they will have found at least one approved MAC which they can use. Hiding the SSID does little more than stopping the neighbours stumbling across the network name by accident.
mhku
Likes
20
TM Nano ~ sg2100
Midlands
#14
And turn broadcasting off.
