Ynkse help
rastiya
Rastiya
from srilanka
asiasat3s
I want to know how to recieve descrambled channels using YANKSE.i have down loaded latest softcam but nothing happens.is it possible to enter the key files by us and how to get an idea of that ?my system is twinhan vision plus sat reciever with CI support,my theator latest vertion.i have tried DVB dream also same result.
rastiya
Rastiya
from srilanka
asiasat3s
can any bodyhelp me to recieve data streams using twinhan vision plus sat reciever with CI.what is the software to do that?is it possible?
Have a look around the forum - theres a whole section devoted to satellite pc cards. The answers will be in there.
Or use the search - up near the top of all the forum pages.
Lancelot
Retired Mod
SS1.
36v H to H 62E - 61.5W
South central
You need to get ProgDvb as it supports Twinhan. (progdvb.com)
Then get S2emu1.18 and a recent softcam.key. As my colleague said, look in the links section.
Then to look at data streams you need Pid scanner and File Grabber. These are both available from the ProgDvb site.
Rgds
L. :)
rastiya
Rastiya
from srilanka
asiasat3s
i will try to find it and reply thanks again.
rastiya
Rastiya
from srilanka
asiasat3s
i got yankse and progDVB and only i can see is FTA channels.i have put the latest softcam key to plugin directory but nothing hapenns.in show monitor numbers changing.take zee in asiasat3s,got the conex key 20,21,22 in softcam.but in key section all it says 20(no keys).can anybody help me?
Lancelot
Retired Mod
SS1.
South central
Zee TV is secure at the moment, so you are wasing energy trying to open it.
If you have a big enough dish you try some of the Hotbird channels with ProgDvb and Yankse.
Rgds
L.
rastiya
Rastiya
from srilanka
asiasat3s
i don't think hotbird path not available in sri lanka,what about PowerVU in asiasat3s?
Lancelot
Retired Mod
SS1.
South central
PowerVu requires a special professional reciever that is not available to the public i'm afraid
L.:)
