Zenega CD 1004IS - Help me please
member91040
member91040
DISH TV,DIRECT DD+,
TATA SKY,HATHWAY,
NOKIA 9660S,
PCI SAT CARD TWINHAN NSS6, PAS7/10, ASIASAT3S, INSAT,INETEL SAT, EUROSTAR, DremBox, & Multi LNB'S
INDIA
ghani_pak said:
HI Member91040.
what is u r location. In which country u r using this receiver. i m in Sharjah UAE
Bro i am lot more far from you, But i can help u...! INDIA.
J
JALAL786
MEGABOX DEGITAL SATELLITE RECIVER DV3
DUBAI,U.A.E
PLS HELP ME I HAVE PROB. WITH MY reciver zenega -cd-1004is i pay the subcription regularly but all of a sudden i recive only 16 channel of star but no other channels i used to get all channels before what must i do can u guide me, i also tried to upgrade my softwRE BUT COULDNOT DO IT PLS HELP ME:-rofl2
JALAL
DUBAI,U.A.E
O
odiyan
OdiYaN
ZENEGA DISHTV
ME
JALAL
DUBAI,U.A.E
Rescan your STB. Althought you may miss some channels, by rescanning you will get most of the channels.
asdf68
NSS6,DISH TV INDIA,KAON KSC-i260MCO
bahrain
Hi odiyana,
Thanx forintroducing modified splitter to increase signal quality.I am getting benifited by this.Any new ideas?
M
mohamedshahid
WINDOS XP
KERALA.MALPPURAM
Zenega CD 1004IS STB TO STB N-M cable HOW PLS HELP
afancier
afancier
Zenaga STB CD1002S, Three solid Ku band Dish. 60Cm,70cm,90cm getting Nss6 95E, Yamal201 90E, ABS1 75E, EuroBird2 26E at 26E. Disec SWITCH
Amritsar
tell clearly what u wanna do with STB to STB................ _http://www.jackelixir.info/Downloads.html may it help u.............
ajaystarin
Zenega Receiver
India
Thanks friend 4 the valuable information provided by you in your website _http://www.jackelixir.info
D
deep_production
hi
india punjab faridkot
For Zenega 1004is,Zenega 1005s,Zenega 1006s,Zenega 1002s (Software v1.56(oct 19 2006)
Code for ZENEGA 1004 old Software 15935764 and New SOFTWARE 86427531 ENJOY
Press menu==>press these numbers 15935764 (v1.55 or v1.56)=== go to Data Download ==Ok
or
if above not works try these cods
press menu==>6843
or
press menu==>9009
for new version utility code is 86427531 (v4.45)
using rs232 cabel (pin5<->5,pin2<->3,pin3<->2) very simple cabel
i tranfer new to old version and see all free to air channels
srei
srei
coship receiver 2000,Dreambox 500;2 ku3cband dishes of 2,4,6&amp;8feet,amd 64 pc with 1GB ram usb tv tuner card
north west india
This receiver should be made to receive FTA channels,bros ,let's share the experience ...make effort collectively ...and make it possible.
B
bipinchungath
no
malapuram
dspdsp said:
Please refer experimenting with zenega you will get loader and steps to follow.
Utility Password is: 86427531
what is the use of utility password used in dishtv,can we get the software for dishtv receiver.please send me the information to my email id I_am_a_nitwit@breaking_rules.com
srei
srei
north west india
Pl describe clearly the difficulty you are facing to get help from Forum,else google it.
ajayvats
amd 4200 x2 1gb Gigabyte GA-MA78GM-S2H, dishtvDISH/FTA recvr.
DELHI
hi deep, can you help me in unlocking my zenega cd1004is to make it fta ? it currently has the latest dishtv firmware.
ajayvats
DELHI
or
press menu==>6843
or
press menu==>9009
Hi deep,
Do you have cd1004is zenega stb old software (with tp/freq edit etc)
ajayvats
ajayvats
DELHI
Has any one got success in getting his CD1004is ZENEGA converted into FTA Receiver. ?
D
deep_production
hi
[_http://www.geocities.com/deep_production/zenega_1004is_solution/menu.jpg[/IMG][IMG]http://www.geocities.com/deep_production/zenega_1004is_solution/software_ver.jpg[/][/]
_http://www.geocities.com/deep_production/zenega_1004is_solution/no_update.jpghttp://www.geocities.com/deep_production/zenega_1004is_solution/chennel_list.jpg[/]
_http://www.geocities.com/deep_production/zenega_1004is_solution/edit_sat.jpg
D
deep_production
hi
Hello!! everybody . i degrade my zenega 1004is software. its only possible changing chip.(zenega1006 and zenega 1004s degrade software with rs232) but when i try to degrage my 1004is with stb to stb software not change then i changeing chip with 1004s receiver.( v3.00 jan 2 2006) no upgrage againnow i see free to air chennels ,edit tp,edit sat,and very easy to use
_http://www.geocities.com/deep_production/zenega_1004is_solution/0919113606_7.jpg[/IMG]http://www.geocities.com/deep_production/zenega_1004is_solution/0919113606_6.jpg[/]
_http://www.geocities.com/deep_production/zenega_1004is_solution/0919113606_2.jpghttp://www.geocities.com/deep_production/zenega_1004is_solution/0919113606_0.jpg[/]
_http://www.geocities.com/deep_production/zenega_1004is_solution/0919113606_4.jpghttp://www.geocities.com/deep_production/zenega_1004is_solution/0919114016_2.jpg[/]
[B]Links and Advertising
* Please do not post live links to [COLOR="Red"]ANY[/COLOR] external sites whatsoever , disable the links by using an underscore as in the following _http://www.example.com, this also applies to photos, please use the manage attachments facility at the bottom of the posting template and upload your pictures, don't use image code or link to them.[/B]
ajayvats
DELHI
hi deepproduction
can you give me any details / contacts for getting my cd1004is fta. Where from are you in india ? you can PM me or EMail me at the adress in my profile
akdesarkar
Dish TV, Zenega 1004iS
India
hi deepproduction
What are the Chips used in Zenega 1004iS? In Tuner is it SL1935D? In Channel Decoder MT312C? Microcontroller ? Flash ROM ? SD RAM? From where can I get Circuit Design? Which chip u hv changed? Apart from chip any other components are to be changed to make it FTA? Without changing chip can it not be FTA-- in the manual it is written by removing the card you can see FTA channel-- is it possible?
akdesarkar
India
URL Links removed to pictures not required nor desired Admin
This is for what? Software upgradation or degradation? R U sure the Edit Sat TP are available in new software? I Hv purchased the STB on 26.9.2008 upgraded the software & watched free review. I have problem of activation --I want to make it FTA. Please explain step by step. Thanks--- akdesarkar*yahoo.com
srei
srei
north west india
I would appreciate if someone from us is able to make MPEG-4 (so called b.i.g) receiver FTA and explain in the forum.
