Zone 2 On A Moteck DiSEqC Motor
Robbo
Retired Mod
www.mbcsatellites.co.uk
Gravesend,Kent,UK
compufunk said:
Thanks for clearing that up guys,:cool:
I had to draw myself a little diagram to prove it to myself :p
Exactly what I originally had to do too.:-rofl2
guest poster
registered
We used a zone 1 Sky dish on a motor for ages... mid UK... 42e to 45w 5000 channels plus... They are very good and the LNBs are...
guest poster
registered
satelliteman said:
Not all of the sats would of been reliable though on a Z1 for sure.
See also: http://www.satellites.co.uk/satelli...ations/123804-zone-1-moteck-diseqc-motor.html
45e (if in sight & further) 42e 39e 36e 33e 28e 26e(1) 23.5e 19e 16e 13e 10e (9e) 7e 5e 1w 5w 7w 8w 12.5w 15w 18w 22w 27.5w 30w 43w 45w (and 58w if in sight)
You miss weak TP/ beams on some sats but not the whole sat... and the signals you do get are usually very strong just like Sky... just set it up well and it'll do it.. they make an ideal dish to stick high up on a chimney on a motor just to get deep east/ west sats that a bigger dish can't see lower down.
Try the dish 'level' at 28.2e to max it out - unscrew some of the bolts and swing it round until its level while the motor is parked at 28.2e and hold it with a G clamp etc.. set the LNB to your zone. The scala rings in the LNBs are also offset for 28.2e as well as oval.
:cool::cool::cool::cool:
*only kidding about 7w.. te he:-pointer
Robbo
Retired Mod
Gravesend,Kent,UK
Still, getting something off 26E ain't bad, which tp is that?
guest poster
registered
It was PALMEDIA on 12739 H 2400 (a feed) but it's become too unpredictable
- however, another has replaced it...
.......121(8)2 H 16200.. (YEMEN TV etc)
you'll get that on a Sky z1 dish now (here anyway ..mid UK)
and a good TP to locate 26e when you're setting a dish up, .... .
...easy as Sky at the moment.
And not 27500 so you don't confuse it with 23.5e or 28.2e
bigtee
Sky; Raven 90 multi-LNB 1W,5E, 7E, 9E, 13E 16E, 19E, 28E; 60cm Triax dish on Moteck SG2100 motor; Various Receivers
Kent, UK
Actually, 12182 H 16200.
fergyc
VU+ Duo with ViX and OSCAM, Prof Revolution 7301 PCI Card, 2x Dreambox 500S, 80cm Technomate Dish with Inverto Black Ultra and TM-2600 DiSEqC Motor. Technomate TM-300D along with a few zone 1 minidishes that get moved regularly and a zone 2 for 19e a
Northumberland
Hey mate,
Having a lot of trouble trying to do this. The Sky poles a lot thinner than the motor one so even if I pinched it, it wouldn't fit. any advice?
fergyc
Northumberland
I used a grinder ;)
edbe
Eygelshoven NL
