- Jul 2, 2005
- Location
- Epping Forest
- Epping Forest Essex
New list with Satellites starting @ 53 east through to 45 west with feed satellites in sequence with extra spaces at the start, middle & end of this new Satellite list made on the TM5302HD+ 88 cm dish 53 east to 45 west it has taken me all day to manually compile this new list as the channel editor cannot perform these tasks,
If you plan to make your own list then you will be advised to save each change to a USB stick & the receiver internal memory,
I did factory reset 3 times as I progressed through the changes from 53 east to 45 west then factory reset & turn off the mains power supply to drain the previous memory,
I then reload the latest channel list.
The finished channel list was edited on the TM5502HD + 100cm Gibby.
Failure to follow these guidelines will result in the DiSEqC 1.3 motor control moving in the wrong direction.
