Personally, I would ask a moderator to separate posts / threads.
Personalmente, pediria a un moderador que separe los post/hilos.
@hairybadger
Millon's questions ....
A.- I worked well a while and after X time began to give problems?
B.- From the first day, gave problems?
Try a simpler configuration, to verify that it is not a problem of switching, put a DiSEqC 4x1, they are very cheap and you will have less losses, for example (DiSEqC A/B/C/D) with the satellites that you have (13E, 19.2 E and 28.2E), do not forget to put ...
Send DiSEqC only when changing satellite [NO]
Every few seconds, once again the satellite switching command, for some problematic DiSEqC, solves the switching problem.
It is not normal, check that the Tuner is well punched in the
slot, sometimes it leaves the end and is partially connected, remove the cover and press at the end, off and the other hand touching the side plate, watch out for the power supply .
Also clarify if you have a double/twin tuner or are 2 singles, using the
2 slot you have (the third only is a cover).
Preguntas del millon....
A.- Funciono bien un tiempo y despues de X tiempo empezo a dar problemas?
B.- Desde el primer dia, dio problemas?
Prueba una configuracion mas sencilla, para verificar que no sea un problema de conmutacion, pon un DiSEqC 4x1, son muy baratos y tendras menos perdidas, por ejemplo (DiSEqC A/B/C/D) con los satelites que tienes (13E, 19.2E and 28.2E), no olvides poner...
Enviar DiSEqC solo en cambio de satelite ....... [NO]
[Foto configuracion tuner B]
Cada pocos segundos manda de nuevo la orden de conmutacion de satelite, para algunos DiSEqC problematicos, soluciona el problema de conmutacion.
No es normal, verifica que esta bien pinchado el Tuner en el
slot, algunas veces se salen del final y esta parcialmente conectado,
quita la tapa y aprieta al final, apagado y la otra mano tocando la chapa lateral, cuidado con la fuente de alimentacion.
Aclara tambien si tienes un tuner doble/twin o son 2 sencillos, usando los 2 slot que tiene (el tercero solo es una tapa).
