Advice Needed Enigma 2 error with BeoutQ PMT pids
Masrawysat
Hispasat 30W ---> Yahsat 52.5 E
Cairo
hi all
from 2 days BeoutQ work at Badr 26 freq 12207 V 27500
Hevc freq
channels downloades on my Dreambox 525 HD as Data channels without Pids
but when I put pids manually through dreamset ,it gave me Error in reading Pmt and show to me N/A
the main problem is Pmt shows as unknown so channels aren't dycrypted
any help ?
pics from Card sat for the package shown worked
Is the DB 525 UHD (HEVC) compatible? NOT just HD but UHD
In that case you wont get anything meaningful from it on UDH / HEVC frequencies..
Masrawysat
Cairo
on UDH / HEVC frequencies i got hd channels only
not uhd channels
Tururu
Assembled with recycled parts
Recycled as the owner.
not uhd channels
The channel in theory is HEVC and then HD channels come out ... OK
Reviewed with VU + DUO2 .... HD
Reviewed with VU + Ultimo4K (4K UHD).
The 2 receivers tune in to the same channels, if you notice, there are not all the channels that you sample (SID), besides, it seems that our receivers are not compatible with these tests/channels.
El canal en teoria es HEVC y luego salen canales HD.....OK
Revisado con VU+DUO2 ....HD (Enigma2)
Revisado con VU+Ultimo4K (4K UHD). (Enigma2)
Los 2 receptores sintonizan los mismos canales, si te fijas, ya no estan todos los canales que muestras (SID), aparte, parece que nuestros receptores no son compatibles con estas pruebas/canales.
Nota:With the DUO2 I do channel fishing, including 4K (UHD)/Con el DUO2 realizo las pescas de canales, incluidos los 4K (UHD).
PC cards on these issues are more advanced and are better/La tarjetas de PC en estos temas estan mas adelantadas y son mejor.
not uhd channels
Thats correct behaviour for your receiver if they are hd only and not coded as hevc.
Masrawysat
Cairo
wait sir
dream multimedia luanched last year 2 new kind of boxex
Dm520-525
DM 900
Dm 520 can receive freqs with H265 like transponder in the picture and watch channels which coded by H265 but can't watch 4K channels
Dm 900 can receive freqs with H265 coding and 4 k channels
Masrawysat
Cairo
thanks for your reply
those are illegal channels which stole matches from be in sport arabia
they crypt pids video and audio, also biss key
It sounds like its something like the situation on 30W with the Albertis DTT transmissions. Those took some very talented lads many weeks to open up, and the solution for watching them on an Enigma2 box is not particularly simple.
Masrawysat
Cairo
exactly
now pids
Q1
vpid:5790
apid:6954
Q2
vpid:5125
apid:3791
Q3
vpid:6705
apid:2014
Q4
vpid:2802
apid:6618
Q5
vpid:2312
apid:3934
Q6
vpid:2789
apid:5357
Q7
vpid:5457
apid:7053
Q8
vpid:2421
apid:5602
Q9
vpid:5588
apid:4165
Q10
vpid:4801
apid:7901
cw: removed - admin
and work through card sat and Chinese boxes well
by add one channel through pids which not available in enigma 2
hitech2016
Satellites
Morrocco
100% sur echolink open v7*9
Pinacle 9100+ hd
