New study object , unknown dish
Trust
Nijmegen Netherlands
Got me this equipment , infact I was just interested in big feedhorn .(dia 150 mm ) but also the mount is very nice .
Effective dish size 880 mm round , dept excactly in the middle 65 mm , unknown brand just marked 0178-890
On the Turtle Hughes Personal Earthstation , lnb NJR2184HH
s-band
Essex
Looks like something thats come off a bookies or a filling station.
Terryl
Custom built PC
or the back of a lorry.
Hughes PES used a 1983 series antenna from memory.
RimaNTSS
Some SAT-related hardware.
N-E from Riga
Effective dish size 880 mm round , dept exactly in the middle 65 mm , unknown brand just marked 0178-890
Congratulations Wim, you've got nice Prodelin dish! Even it is round it still an offset, and that is cuz it's face not flat. If you make string test you will see. Mount is typical Prodelin design.
And, taking into account it is last day of 2017, what else should I say, something nice ...... the dish is dirty, and you need at least an hour to wash it :-doh
archive10
Yup, it's a prodelin 0.8 f/D dish w. 0.8 f/D feed, OEM'd to Hughes brand.
Gas stations in europe seems mostly to have Channel Masters from what i have seen, whereas the prodelin ones i have mostly seen on supermarkets such as Intermarché in France... could be different i the Netherlands, of course.
Nice dish, tho.
Trust
Hi Rima , did'nt notice that curved front edge bevor , glad you pointed me to that .
Later this week I will connect that existing lnb to my satmeter , point the dish to a sat and will see whats comming out .
I know its for one polarisation and has restricted band .
Also want to attach that feedhorn to the 1.2 CM and compaire it with other lnb /feedhorn combinations .
That horn has a short neck , so restricted adjustment , maybe even the side rods are in the way .
archive10
This will be interesting... in theory, you shoud be getting less of a signal, as the 0.8 feed will (in theory) be looking at less of the CM than a matched CM feed,
On the other hand - the feed is a large and well-designed item, so perhaps it will work better than the standard fare??
Only one way to find out - experiment!
