bracket for disecq motor
saj1985
Dreambox 800HD SE, Dreambox 500S, Skybox F5S, 90cm Solid Dish, Tm2600 Motor, Inverto Black Ultra LNB! :)
Lost...
hey peeps, i wanted to use the tm2600 (technomate) motor ive got with the fibo 90,
i was wondering where can i get a bracket to connect the dish to the motor?
saj1985
Lost...
any ideas as to where can i buy it from?
RimaNTSS
Some SAT-related hardware.
N-E from Riga
Could you show some pictures to understand what exactly should be connected?
saj1985
Lost...
this is the back of the dish where the original motor goes on,
its length is approx 13cm and the width is 7.8cm
i need a bracket to connect to holes on the back of the dish and so i can connect it to the tm2600 disecq motor
hope what im saying makes sense
RimaNTSS
N-E from Riga
I see. I thought you are going to use original polarmount and Fibo motor. So, you probably need to make customized bracket. I will think about it tomorrow.
saj1985
Lost...
i am planning to use the original motor but not sure if it works yet,
my father in law is checking it out for me as he's a retired electrician
also the wiring on the fibo motor seems different compared to just one coaxial wire for the technomate motor
how do i go about making one? im so crap when it comes to diy lol
RimaNTSS
N-E from Riga
It is never late to start DIY.
To control Fibo motor you need positioner and additional 4 (in some cases 5) wires from room to antenna.
saj1985
Lost...
how much do the positioners normally cost about?
i'll have to keep a look out for one
RimaNTSS
N-E from Riga
RimaNTSS
N-E from Riga
saj1985
Lost...
Not really. That is from my memory. I just sold 2 used positioners for 30 EUR.
you got any left?
once i find out if the motors working i'll try to get one
RimaNTSS
N-E from Riga
I have several but also have plans how to use them. Can ask in the shop, maybe they have some new left.
Trust
Nijmegen Netherlands
I made sevaral from Moteck and STAB mastclamps .
Also complete one from other material with the dish as close as possible to the rotor .fibo fix moteckmount.jpgfix stab clamp.jpgshort builded clamp full.jpgshort builded clamp parts.jpgshort builded clamp topview.jpgshort builded clamp.jpg
saj1985
Lost...
Trust
These are long gone , but I can build one .
saj1985
Lost...
Trust
saj1985
Lost...
all sorted @Trust1 is going to make me a bracket for the fibo and also do me a lnb too
@Trust1 thanks mate i really appreciate it
