Octagon SX8 HD ONE (aka Mini or Magic)
dxsatellite
openbox
zemlja apsurda
Interestingly when you update from the Octagon site, the sw contains no PVR function, but from another site it does!!
stephan94
Bavaria
A sample in C Band with Blindscan to 40 ° East (I'm only with 1.20 antenna).
There are also multistream found in T2MI.
No problem with the SX8, just with a little trick. (even 54 frequencies are found)
First: make a blindscan in blindscan mode (not blindscan multistream) He finds all transponders but not the programs that are in MIS or T2MI.
Second: scan all found transponders and there he really finds all programs
MCelliotG
Thessaloniki, Greece
Because it would take tons of time to scan each frequency with the so-called "blindscan" parameters since the table it uses for its virtual MIS/T2-MI discovery is getting larger and larger....
Could do with Octagon correcting the amount digits on display on the info bar for symbol rates. It will only display four when actually it is 29900. Bottom right on my picture.P1010016.JPG
I really don't understand why folk get so concerned about the occasionally missing zero. It really is nothing.
I know it is not a big issue, but if it can be corrected, why not?
Lol. 'twas a joke ...... zero . nothing ..... :p
Really I should be used to the 'Yorkshire sense of humour' by now....I'll have to get it in gear for next week..
RustySpoons
Sleepy Hollow
50E - 30W
2x CM 1.2m Polar Mount/Jack
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
It's easier to correct things on the SX88/+ as that's Linux and software based. The SX8 HD is chipset based and limited to what they can adjust in firmware.
sami noor
ASTRA 19°E/5°W/7°W
ALGERIA
SW UPDATE DEUTSCH
Datei ALL:
SW mit Senderliste und Multimedia Funktionen.
Vorhandene Senderliste und Einstellungen werden gelöscht!
Menü - Systemeinstellung - Firmware aktualisieren - OK Taste
USB-Aktualisierung - Abschnitt:
ALLES (Vorhandene Senderliste und Einstellungen werden gelöscht)
APP (Senderliste und Einstellungen werden beibehalten)
Dateipfad - OK Taste: SW Datei auswählen - OK Taste
Anfangen - OK Taste
Installation startet (Dauer ca. 2min.)
Datei APP:
SW ohne Senderliste und Multimedia Funktionen.
Vorhandene Senderliste und Einstellungen werden NICHT gelöscht!
Anfangen - OK Taste
SW BACKUP DEUTSCH
Software, Senderliste und Einstellungen können auf USB Medium gespeichert werden!
Erweiterungs Typ: Dump (Backup) auswählen (mit rechts / links Taste)
Dateipfad - OK Taste - USB wählen mit OK Taste (/mnt/usb01/02)
Anfangen - OK Taste
Backup wird auf USB gespeichert (Dauer ca. 2min.)
SW UPDATE ENGLISH
File ALL:
SW with inside Channel list and Multimedia -- # # --s
Existing Channel list and User Setups will be delete!
Menu - System Settings - Software Upgrade - OK Button
USB Upgrade - Section:
ALL (Channel list and User Setups will be delete)
APP (Channel list and USer Setups will be keep)
File Path - OK Button: Select SW file - OK Button
Start - OK Button
Installation start up (Takes arround 2min. Time)
File APP:
SW without Channel list and Multimedia -- # وصلة ممنوعة 1778 # --s
Existing Channel list and User Setups will be keep!
Start - OK Button
SW BACKUP ENGLISH
Software, Channel list and User Setups can save to USB storage!
Upgrade Type: Select Dump (Backup) (with right / left Button)
File Path - OK Button - Select USB with OK Button (/mnt/usb01/02)
Start - OK Button
Backup (Dump) start save to USB storage (Takes arround 2min. Time)
SW UPDATE TÜRKISH
Dosya ALL:
Kanal Listeli ve Multimedya özellikli yazilim
Kanal listeniz ve ayarlariniz silinir!
Menü - Ayarlar - Yükseltme - OK Tusu
USB`den Güncelleme - Bölüm:
Tümü (Kanal listeniz ve ayarlariniz silinir)
Uygulama (Kanal listeniz ve ayarlariniz silinmez)
Dosya Yolu - OK Tusu: Yazilimi secin - OK Tusu
Baslat - OK Tusu
Yükleme baslar (Süre: 2 dakika)
Dosya APP:
Kanal Listesiz ve Multimedya özelliksiz yazilim
Kanal listeniz ve ayarlariniz silininmez!
Baslat - OK Tusu
SW BACKUP DEUTSCH
Yazilim, Kanal Listesi ve Ayarlarinizi USB`ye yedekliyebilirsiniz!
Güncelleme Tipi: Dump (Backup) secin (sag/ sol Tusu)
Dosya Yolu - OK Tusu - OK Tusu ile USB secin (/mnt/usb01/02)
Baslat - OK Tusu
Dump (Backupunuz) USB ye yedeklenir (Süre: 2 dakika)
SW Änderungen / Changes / Degisiklikler
English:
- Subtitle and Teletext problem solved
German:
- Videotext und Untertitel ANzeige verbessert
Turkish:
- Videotext ve Alt Yazi iyilestirildi
CAS Menu Aktivierung /Activation
Menü - Systemeinstellung: PIN 6363 --> CA Setting (unten)
Menu - System Settings: PIN 6363 --> CA Setting (Bottom)
MENU PIN
--> Default PIN: 0000
--> Master Passwort: 8765
06/04/2018
OCTAGON_SX8-HD-ONE_SW-CA_20180406(2).rar
4Himdj
1.2 Laminas Dish
Rome
Well it is is the Sony TV that is at fault. tried on a Toshiba and perfect sound on the French Multistream channels.
I've octagon 4008 connected to a 2016 sony bravia tv. french multistream audio is ok
octagon sx8 connected to the same tv with the same hdmi cable gives no audio on french multistream channels. (I've tried on 2017 philips tv also - same issue)
what's wrong?
then I've freezing on some french multistream like L'Equipe tv despite of 14,2 db and no problem on octagon 4008
thank you in advance best regards
The SX8 doesn't support Dolby D+
You need the SX88+ for that.
RustySpoons
Sleepy Hollow
50E - 30W
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
No.
You'd need the SX88+
The SX8 HD ONE is the SX8 you referred to in the post I replied to.
It is referred to variously as SX8, SX8 HD ONE, SX88 Mini or SX88 Magic, but it's the same device.
But if your TV is DD+ capable, it shouldn't matter which receiver you use.
Edit: @RustySpoons Snap!
RustySpoons
Sleepy Hollow
50E - 30W
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
Or with a AC3/DD+ AV Receiver :)
4Himdj
1.2 Laminas Dish
Rome
No.
sorry I don't understand so I ask for your kind help:
I've an octagon 4008 connected to a sony 2016 tv (55x8508c): no problem with french multistream
what do I should do with sx8 connected to the same tv?
KD-55X8508C Specifications | Sony UK
thank you
best regards
