OCTAGON SX88 H.265 HEVC HD
sat-tv-fan
East Sussex, South East UK
(66 E) 42 E - 45.0 W
Azbox HD Premium
Azbox ME
Amiko A3 combo (android)
TBS 5925 and 5927 USB
GT Media V8
Octogan SX88+
Octagon SF8008
Koqit K1 mini
Openbox SX6 HD
Mecool K3 pro (android)
X2 Premium HD
Skybox F3
Technomate 5302 HD
Technomate 5402 M3
iSmart X8
OK thanks for that but while I wait for my SX88+ to arrive (SX88 sent back today) I am trying with my TBS 5925, as I say not a trace of any signal
I do not understand why you cannot get the NURTS Bulgaria multi stream from 39 east
Good signals here with a 88cm dish ?
Can you pick up The Voice on 12524 H 30000 on Hellas Sat @ 39 east ?
sat-tv-fan
Azbox HD Premium
Azbox ME
GT Media V8
Octogan SX88+
Octagon SF8008
Koqit K1 mini
Openbox SX6 HD
X2 Premium HD
Skybox F3
Technomate 5302 HD
Technomate 5402 M3
iSmart X8
Nope can't get that either, my LNB has had it, very old now. been trying for years to get someone to change it over but impossible
If the Lnb is working OK on other satellites it may mean that your dish needs to be realigned better to improve your tracking of the satellite arc if your system is motorised.
Is the dish accessible?
If so, changing the LNB (If that really is the problem) is a simple DiY task.
Otherwise, have you tried Posting in our Installer Wanted section?
sat-tv-fan
Azbox HD Premium
Azbox ME
GT Media V8
Octogan SX88+
Octagon SF8008
Koqit K1 mini
Openbox SX6 HD
X2 Premium HD
Skybox F3
Technomate 5302 HD
Technomate 5402 M3
iSmart X8
Otherwise, have you tried Posting in ourInstaller Wantedsection?
No it's not accessible by me, I need someone with a tall ladder, it's probably out of alignment yes
sat-tv-fan
Azbox HD Premium
Azbox ME
GT Media V8
Octogan SX88+
Octagon SF8008
Koqit K1 mini
Openbox SX6 HD
X2 Premium HD
Skybox F3
Technomate 5302 HD
Technomate 5402 M3
iSmart X8
LateAdopter
80cm fixed, 4 position switch
28.2 E, 19.2 E, 13 E, 5 W
Xoro HRS8500, Edision Primo
I tried to record with a 128GB USB 3.0 flash drive but nothing happens, I presume you have to use a USB hard drive ?
USB sticks and SD cards of 64GB, or more, come formatted exFAT which won't work.
You need to reformat it to FAT32 with 64kB (128 sector) cluster size. The default cluster size for FAT32 is too small for recording video, so you have to specify the cluster size when doing the formatting.
Do not delete or move the partition, or you may lose the alignment, just reformat it.
I have a 64GB SD card, formatted that way, that works fine with my Primo as does a 1TB disk with two FAT32 partitions.
EDIT It's likely that 128GB will use 64kB clusters by default anyway, so you may not need to specify it. It's more of a problem with smaller capacities.
I have a 16GB Verbatim USB stick that works fine with the Primo.
LateAdopter
Yes, I have a SD card that size too. It came formatted with 32kB cluster size, which works OK. It's if you reformat it that the cluster size would reduce to 4kB, probably, and that would make writing much slower.
stephan94
Bavaria
Octagon_sx88_v1.04.60_20180423_EU NEW SW - 23 04 2018
SW Update: Menu - Settings - SW Firmware Update: USB - OK Button
- Online Firmware Update Remind ON/OFF function add.
- Menu - Firmware Update: PIN 0000
- New SW version remind Enable/Disable!
- Xtream TV Autostart improved:
- Menu - System - IPTV settings:
- Xtream start server: Off/1/2/3/4/Last using
- Menu - System - Misc settings:
- Autostart Menu: Xtream IPTV
- Xtream TV Expired Date function improved
- Stalker VOD Series Category added
- Low Framerate support for IPTV added
Menu - Settings: PIN 6363 --> CAS Setting (Bottom)
FTP enable: Menu - Settings - Misc settings : FTP Server ON
FTP login: root , PW: sky1122
Webif (Web Interface) browser: IP 192.168...
Fast key Editor: TV Mode - Press 0000 Pin. (Biss, Power Vu)
Telnet (Puty): Login: root, Password: sky1122
cccam config import USB: use CCCAM.iks file
Stalker URL Password: 6969
WebTV Password: RED Button (Rote Taste) - +18 - Exit and WebTV again
Kindersicherung PIN 0000, Master Passwort 0088
IPTV OTT Modus: System Information - PIN 9090
S2 + IP Modus: System Information - PIN 9090
23/04/2018
Download OCTAGON_SX88_SW_EU_V10460_230418.rar (41.18 MB) now. Fast and easy at workupload.com
sat-tv-fan
Azbox HD Premium
Azbox ME
GT Media V8
Octogan SX88+
Octagon SF8008
Koqit K1 mini
Openbox SX6 HD
X2 Premium HD
Skybox F3
Technomate 5302 HD
Technomate 5402 M3
iSmart X8
Thanks I did this but the record button just won't work with me using a micro sd card with a usb 3.0 adapter - it senses I have a USB drive connected but that's all. Perhaps I need to update the firmware ?
LateAdopter
You could be right. There are versions of the Octagon firmware with record disabled. Hopefully stephan94 can point you to the right version to use.
stephan94
Bavaria
tiduf
Archived Member
If you want to record with the official FW press the OK button then the red button one time to start recording and a second time to adjust the recording time.
sat-tv-fan
Azbox HD Premium
Azbox ME
GT Media V8
Octogan SX88+
Octagon SF8008
Koqit K1 mini
Openbox SX6 HD
X2 Premium HD
Skybox F3
Technomate 5302 HD
Technomate 5402 M3
iSmart X8
Oh yes that works thanks, so there is non official FW ?!
tiduf
Archived Member
mike1
Non-28.2° Sat Specialist
Yorkshire Television
Triax 64cm triax ( Darkmotor ) Inverto Black Ultra.
T55 - 28E/19E/13E/1.9E
Mutant AX 51 Open PLi
GT Media V7SX
can this box drive a dark motor? it will not short the board.
I'd assume so ..... my Edision Primo drives a DiSEqC motor quite happily and bearing in mind the remarkable similarities (ie virtually everything but the case and connectivity) between the SX88 and the Primo, it'd be surprising if the Octagon fails in this respect.
