- Jul 26, 2003
- Location
- Scottish Borders
- Scottish Borders
Thats pager interference . The bane of the wxsat game in Europe.
That’s with the uputronics pre-amp.Thats pager interference . The bane of the wxsat game in Europe.
137.5MHz Filtered Preamp
And the noo-elec txco dongle. About 6 meters of coax. Plus the pi 3.
And your using this filtered pre-amp?
And still getting the interference?
Then it could be direct RF radiation into the dongle, there could be a break in the shielding somewhere... OH Is the shielding grounded??? that could make a big difference, a standard TV coax ground block (if you used 75 ohm TV coax) can be used to ground the coax shielding, without a good ground it can act as an antenna and pick up high levels of RF that may be close by.
I would suggest using one and a ground rod driven in right at the antenna.(ground the antenna mast also)
I am surrounded by communication masts, from the hospital, police station, sorting office/phone exchange it goes on and onIf you knew what direction the paging transmitters are, you could put up a Faraday shield on the side of the antenna facing that direction, it would look funny but it has worked in the past.
Well it looks like it knocked it down some, maybe some quad shielded coax??
But it could be direct to the antenna.
