RustySpoons
Sleepy Hollow
- Jan 31, 2018
- Age
- 42
50E - 30W
2x CM 1.2m Polar Mount/Jack
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
- South Wales
A quick guide on how to Stream TV from your Edision Primo IP S2 to your PC.
Some of you may already know how to do this, I was just playing around with the box and thought I'd type this up.
If it's not already installed install VLC, then open it:
From VLC go to "View" then "Playlist" Or press Ctrl + L
On the left hand side select "Universal Plug'n'Play" - Accept any dialogue boxes that may pop up.
(Windows users MAY need to change their network from Public to Private and enable network discovery if this box is not showing on the right hand side)
Double click the folder called MS (with the Edision IP address)
Double click the LiveTv Folder, be patient as it might take a while to load all the channels:
You should now see a list of all your channels. Just double click the one you want to watch and it should start playing
I just picked a random channel for this example:
Also under the Media Folder, there is a Record Folder, in here you can watch your recorded programmes
