Music festivals feeds
superpascu2
ATLAS HD100 - ASTRA 19,2 + HOTBIRD 13 + 28,2 1.2m famaval
Alicante
The day has arrived. I am not wrong today!!!
Can anyone look for feeds? Just to be sure and prepare for next year...
superpascu2
Alicante
Finaly whatching via streaming. But would be apreciated if someone could confirm the feed
stephend2017
KU Band: Motorised 1.2m dish connected to a TBS 6981
KA Band: Eutelsat KA-SAT 9e on Ireland spot beam connected to a TBS 6904
Ireland
I checked around and couldn't find anything. It is very likely that they are feeding this through IP and not DVB.
davemurgtroyd
Oxford
Oxford
Isn't it time you set up your own system to check them out or do you have a problem with that? Why the interest if no intention of getting one?
superpascu2
Alicante
I take your point but firstly I want to know if there are feeds available in order next year to prepare the set up with time. I was not possible for me this year. And apart from that I have always wondered if this kind of festivals were transmited live or not in order to prepare news headlines
margusten
Lat 59.40 Lon 24.68
DR.HD F15, TBS-5925, Dream 800PVR, GM TripleX
Aerial AS24 polarmount 95E - 13E Ku+C, fixed 3M 28.2E, 27.5W ...
Estonia
Isle of Wight Festival | UltraHD RExt 4:2:2 | 16APSK
Astra 3A-3B (23.5°E)
Frequency: 11675 - Pol: H - SR: 33333 - FEC: 3/4 MPEG-4 4:2:2
Scrambled?
stephend2017
Ireland
Has anyone had any luck watching this feed? My 32 core system is struggling with it. I'm wondering if a new graphics card would be able to play it.
23.5°E 11674, H, 33333 16APSK FEC 3/4 IOW ENC3 (SKY) 4:2:2
Isle Of White Festival in UHD !
enc in Biss
Nothing in 4:2:0 found so far :(
You may be able to play this feed on a tbs satellite card via a computer.
stephend2017
Ireland
That is what I’m doing at the moment but it seems my PC is not powerful enough to decode the feed
You probably need a professional receiver for this feed then as they obviously do not want anyone except the broadcaster to receive this transmission.
margusten
Lat 59.40 Lon 24.68
Estonia
Same problem here. Using DVB Dream. HEVC codec needs powerful hardware support, only CPU can not handle this. What H.265 codec You are using? I have LAV Video Decoder 25.10.2013
Dave5118
1.5m Gibertini with Inverto 5434 Unicable Hybrid LNB.
TBS 6903 with EBSPro
Vu+ Uno 4K SE
Edision OS Nino Pro
Starsat 2000HD Hyper
Sky Q Silver
Sky minidish with Sky Q Hybrid LNB
Nr Manchester UK
Looks like it could be a Codec issue, as my Ryzen 1800x is only running at 50% on this feed, but still not stable. I think the fact they are using 10 bit colour may be a factor too, as I saw a Portuguese league game in HEVC 4:2:2 once and that was more stable with only a minor stutter...... was lesser bitrate though.
stephend2017
Ireland
I'd love to find out which setup can play this with minimal stutter. However this is some seriously demanding video that probably requires professional hardware. I'll do some research!
stephend2017
Ireland
Any upcoming festivals that will be broadcast on tv?
stephend2017
Ireland
TRANSMT isn't being broadcast on satellite as far as I know. I think they are just recording, not broadcasting
The Rascals
Clarke-Tech 5100C, Freesat V8 Super, Stab HH 120 Motor, Laminas OFC1200C
Cork
TRANSMT Festival (pre recorded)
16E: 12688Ghz V 14399Ms ID = UKI-1921P1
The Rascals
Cork
As Post #39 still active
