Advice Needed DVB-S2X & Multistream TBS Sat Card
Archive-8
My old Tbs 6983 card will not see any dvb-s2x transponders as the card is not compatible.
The 6522 card will do dvb-s2x but not Multistream, from what little spec I can find.
Do tbs make a newer model card that will do dvbs2x and Multistream (ideally a professional card)
As this new card I hope to replace the 6983.
Many thanks.
archive10
The specs for the 6903 says it does multistreams, but does not mention S2X.
Re the multistreams, I must admit I haven't tried this yet.
lovinthetelly
Sky+HD, Wavefrontier T90 with 16 quad/octo LNBs receiving 42E/39E/33E/28E/26E/23E/19E/16E/13E/10E/9E/7E/5E/3E/1.9E/1W/5W/12.5W through 3 EMPCentuari 16-way DiSEqCs to TBS6522, Octagon SF8008 & Edision Primo IP S2.
90cm for 7W/15W; 1.2m CM in storage.
I've got the TBS 6522 - can confirm that it copes with S2X on 33E and multistream (on 5W, 12.5W, 5E, 39E). Haven't succeeded in getting T2-MI signals to work (though admittedly I haven't tried much). Handy to have four inputs - you change tuner mode between S2/T2 via software.
TBS6522 card lock signal and memorizes the MIS channels at 5.0 W with both Crazyscan and dvbs players(DVB Dream,SmartDVB,etc).
Archive-8
Looks like all I need to do is swap the cards over.
Thanks for the confirmation it will handle Multistream and dvbs2x
That’s saved me a few quid :Y
MCelliotG
Thessaloniki, Greece
The real question here would be:
is there a card that can handle all DVB-S2X, Multistreams and ACM/VCM 8/16/32APSK?
Archive-8
Yes that’s what I was really after, as I want the card a a dvbs2x replacement for my 6983.
The 6908 might just be what I need if I can find it a tad cheaper.
CrazyCat
crazycat69.narod.ru
13E 4.8E 4W: Dish Variant CA-902 0.95m + 3xLNB Ku-Universal DreamSat DS8 + DiseqC 1.0
30W-95E: Dish Strong 0.95m + LNB Ku-Universal ALPS BSTE8-751B + Motor PowerTech DG240
OpenBox X-800
TT S-1401 PCI
Omicom S2 PCI
TBS 5980 USB2.0
Ukraine, Kharkov
Strange question :) Silabs demods support broadcast profile for DVB-S2X, limited VCM suppor. At least DTT DVB-S2 8PSK multistreams supported + PLS code change.
MCelliotG
Yes, at least....
Certainly at this point there is no card that supports all modes for DXers. STV09X demods support full VCM but not DVB-S2X, Silabs the opposite. At this point you need two different cards/tuners for everything.
MCelliotG
BTW can anyone check the Asturias mux on 30W 11496H with either TBS 6522 or 5922? This package was highly problematic with Silabs demods and now seems to have stopped? I get no lock anymore!
s-band
Essex
No lock on TBS5520E (SiLabs) but fine on TBS6983 using root, gold or combo
MCelliotG
Just as I suspected, they must have changed to VCM.
CrazyCat
crazycat69.narod.ru
OpenBox X-800
TT S-1401 PCI
Omicom S2 PCI
TBS 5980 USB2.0
Ukraine, Kharkov
Combo is "fake" from STm :) So must be removed from all GUI's :) This some like Gold, but read-out PLS registers give Root code :) Anyway Silabs demod require Root PLS code and need simple calculation from Gold->Root (implemented in V4L DVB drivers).
P.S. I think 8PSK,8/9 some problematic for Silabs demods :) Need access to real signal and contact with Silabs support.
MCelliotG
This frequency used to work until recently but had a constant periodic lock loss. It looked like the signal was getting lost the second the modulation/parameters were changing to a combination Silabs could not read and get back once the combination was detectable. Since STV090x can handle all these combinations we see stable signals with these cards.
I cannot use my TBS 5925 ftm to see what has changed exactly, but certainly it's something Silabs cannot handle, at least currently, so if anyone can inform us, be my guests!
In comparison the CLM package on 11491V with also 8/9 FEC is always stable.
SatSearcher
West Yorkshire
Seems to be working fine here with TBS5925, also locks fine on Octagon SF4008 (which I think uses Silabs tuners), albeit with some picture break-up, which is a known issue on this mux with these tuners.
MCelliotG
So, not locking on HD51 should be a driver issue? That's interesting!
Archive-8
I sent tbs an email last night.
My email
I currently have the tbs 6983 professional sat card, I am looking for an upgrade to this card to add dvbs2x What cards are equal spec to the 6983 with dvbs2x? Many thanks.
I have just had an email back from tbs
Dear Chris,
Thanks for your email. We'll release a new model soon. Will let you know the latest news then.
Best Regards!
So fingers crossed it will be this year :eek:
CrazyCat
crazycat69.narod.ru
OpenBox X-800
TT S-1401 PCI
Omicom S2 PCI
TBS 5980 USB2.0
Ukraine, Kharkov
PCI is die long time ago :)
