Just Sharing This C-band beacons
I have this beacon looking spike at 4000.80 V at about 42 West. It does not appear to be from an inclined satellite. Was wondering if it's from an active Milsat bird.
Military satellites normally have beacons in the X band ( approx 7.48 GHz) s-band and sometimes the low UHF band.
If you can, point the dish down towards the horizon at the same position. You might have a terrestrial source of interference there,
s-band
Essex
My guess is that it is more likely to be a narrow scpc cluster, possibly from Intelsat 11 43W. hvdh's list only has 3 C band in that region at 40.5, 43 & 45. The SDR will let you see any mod on them.
GEO satellites from 120°E to 90°W
Nothing listed here: http://frequencyplansatellites.altervista.org/Beacon-Telemetry_Atlantic.html
Agreed, that's the info i found as well, but the only sats i found that were listed at 42 deg West were military ones. The signal definitely peaked in the vertical mode and dropped as i went to either 40.5 W or 43 W. Looking at it this morning again, it's a bit stronger and more careful dish nudging puts it around 42.5 W but the problem with the 2.2 PF is that the beamwidth is a bit too wide to get a really accurate fix. If only i had a larger dish with a tighter beam. Tried the suggestion CH, def coming off the arc, thanks both (CH & s-band) for the suggestions.
This might be SES-14 that is still in LEOP, but within a few weeks will arrive at in-orbit test location (still unknown but will be close to 47.5°W final location). No recent TLE's because AFSPC lost track of the satellite. But if the signal moves a few degrees during the day, it's SES-14 probably. A beacon should be at 4198.0 V.
Looking at it this morning again, it's a bit stronger and more careful dish nudging puts it around 42.5 W but the problem with the 2.2 PF is that the beamwidth is a bit too wide to get a really accurate fix. If only i had a larger dish with a tighter beam. .
A 2+m dish should be trackable to within 0.6 degrees, beamwidth is from memory around three times that at higher C band frequencies.
Think of the neighbours.
On the other hand.....
There is a small chance you are getting an extreme sidelobe signal from the ZooMoo transponder on 43W, Intelsat 11.
Iv'e had a scan from 41 to 53West for beacon-like spikes at 4198.0 V but can only see a signal at around 53W at 4198.20 RHC.
I'll have a look into CH's suggestion re: ZooMoo freq.
Can't see any sign of ZooMoo at the marker at the moment at 4003 V, there's possibly just the very slightest sign of a signal trying to raise up but i can't improve on it even after dish nudging when checked at 11.20 am UK.
dx qwer
www.satellitescommunity.de
C-Band: ORBITRON O-16 (4,9m)
Rastatt/Germany
Hello,
ZooMoo frequency has left in Februar this year. I can see a carrier at ~4003 V (probably LOF drift?).
Hello,
Odd, it is still listed as accurate on Flysat as well as Lyngsat. It was a guess on the original frequency though.
Does changing polarity nullify the peak John ?
Yes mate, definitely Vertical pol.
