Panasonic TX-P42GT30B - power cord ?
A customer has brought this one in with a power fault. It was originally installed on the wall by the previous apartment owners.
Having looked through all the manuals and auction sites, there appears to be no specific detail on the power lead this one uses, and Panasonic sites visited don't have anything either.
It is a UK/Ireland model according to the blurb on the rear chassis, and about six years old.
So where do I get the right power lead from, just to plug it in at the office ?20180811_131314.jpg20180811_131322.jpg20180811_131339.jpg20180811_131355.jpg20180811_131426.jpg
A archived auction on Fleabay has this image, but no further detail
I've never seen one like that either (and I've seen quite a few) - couldn't the customer give you his power lead?
Alternatively, could you remove the filter lid and jury-rig connections to the filter i/p terminals??
Alternative 2 - might have to replace the filter with another that has a similar circuit config, but with a more conventional i/p socket design, as it looks fairly similar to many others I've seen.
PS: the Tokin filter catalogue is here and the GL series is right at the end, but that one is not listed - maybe you could contact them to see what they could recommend?
The lead is securely fixed in the wall behind the wall mount, hence it being left on site.
Since it is not my TV I don't want to go down the route of modifying/buying more than is required, then having to convert back once fixed.
CH
See the PS to the above post.
I did, nothing in there that assists a lead for this weekend. I could take the block out completely and run the set off a filtered socket for the time being.
Sounds like the only realistic solution in the short-term :)
Watch where you put your fingers when the power is ON :D
It's all going to be isolated with wood and taped up.
No worries
RustySpoons
Sleepy Hollow
50E - 30W
2x CM 1.2m Polar Mount/Jack
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
Insulated female spade crimps would have worked?
Topper
Amo Amas Amant Admin
Blackburn, Lancashire
Necessity is indeed the mother of invention:eek:
