Advice Needed HDMI Video Sender
The Rascals
Clarke-Tech 5100C, Freesat V8 Super, Stab HH 120 Motor, Laminas OFC1200C
Cork
Have anybody advice on HDMI Video Senders, had a Philips Scart which worked great, but new TV's have no scart.
I want to control my motorised system in the "mancabin"which is approx 30 meters from the nearest house tv across an open yard.
thanks
Terryl
Custom built PC
Check this out.
https://thewirecutter.com/reviews/the-best-wireless-hdmi-video-transmitter/
The Rascals
Cork
Terryl: Thanks for the info had also checked that link, but at £280.00 a bit steep.
I was hoping somebody on the forum had used/tried one of these devices that worked for them.
Run a cable, cheapskate.
Dave5118
1.5m Gibertini with Inverto 5434 Unicable Hybrid LNB.
TBS 6903 with EBSPro
Vu+ Uno 4K SE
Edision OS Nino Pro
Starsat 2000HD Hyper
Sky Q Silver
Sky minidish with Sky Q Hybrid LNB
Nr Manchester UK
Just wondering..... what happens if you try and use a HDMI extender over homeplugs? Just a thought, not used video senders for years tbh, and HDMI ones never seem to get good reviews overall. Always assumed extenders using cat cables was the only way really for HD.
You could also use digital modulator, you would need to run a coax and use a freeview receiver in your den. The newer ones from Technomate also support the magic eye system for your remote signals.
Terryl
Custom built PC
The homeplug power-line LAN interfaces do not have the high frequency response needed for the HDMI to CAT 5/6 converters, the HDMI to CAT 5/6 interfaces need two CAT 5/6 cables to handle the HDMI HD signals, and have to be dedicated cables.
Any other signals running on top (or below) of the HDMI signals would cause all sorts of problems, the power line interface adapters have handshaking signals to find each other.
The Rascals
Cork
Thanks to everybody for your responses.
Running cable is not possible as the 30 Meters between the "mancabin" and the house is used for tractor and trailer to get into my very large back garden, and the Mrs does not want to see cables in the sky when she looks out the patio door.
Is there a SCART to a HDMI converter?
Terryl
Custom built PC
Check this out.
http://www.techturtle.co.uk/convert-scart-to-hdmi/
Can you dig a trench??/ This way a 3/4 inch PVC conduit can be run out to the mancabin.
All you would then need would be 2 CAT 5 or 6 cables out to the mancabin and the two HDMI to CAT 5/6 adapter, plus the SCART to HDMI adapter.
davemurgtroyd
Oxford
Oxford
A method I used some years ago was making my own UHF transmitter.
Feed RF output of modulator (works with either analogue SD or digital HD modulators - for a while I used old VCRs fed with composite video from stb) into a UHF amplifier. Feed UHF amplifier to a portable TV UHF aerial. On receiving TV plug in portable aerial and tune TV to modulator output channel (may also work with main aerial if connected). With varying powers of UHF amplifiers I was able to get good reception from 10 meters up to 100 meters.
Strictly speaking this is illegal but if you live in the sticks and have no nearby neighbours then no problems
So, where did you get your transmitting licence from?:-lmao
(OTOH, many years ago when I worked at HP at Filton, Bristol, we had a roof-mounted EMI test range. That needed to be calibrated, which meant transmitting from one antenna to another up to 30m away. We were in clear sight of the TV transitter towers South of Bristol and the BAE Systems plant at Filton aerodrome - no licence but never got caught! :-lmao)
Terryl
Custom built PC
Ham radio operators can transmit SSTV on certain UHF channels, the equipment is available, but no one that I know of is doing digital HDTV.
I got my experimental TV license back in the 70's, I could go up to 1500 watts ERP if needed.
Rolls Royce. They subcontract HP for their IT stuff. Head offices are in Derby but RR obviously have a huge presence in Filton. I did some contract work there...
HP?
Saucy!
(Dons coat, exits stage left)
RR were probably somewhere at Filton at the time (late 1980's) but it was mainly BAE (or whatever it was called at the time) - took our first HP Bristol (mainly a storage peripherals R&D and manufacturing site at the time - but now long gone, I think) product into the BAE Environmental test labs for some shock & vibration testing, and it then stayed there for 2-3 weeks when they went on strike :-doh
RustySpoons
Sleepy Hollow
50E - 30W
2x CM 1.2m Polar Mount/Jack
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
Yes we do transmit Digital and Analogue television :)
