Music festivals feeds
Dave5118
1.5m Gibertini with Inverto 5434 Unicable Hybrid LNB.
TBS 6903 with EBSPro
Vu+ Uno 4K SE
Edision OS Nino Pro
Starsat 2000HD Hyper
Sky Q Silver
Sky minidish with Sky Q Hybrid LNB
Nr Manchester UK
Reading Festival - Main Stage
Satellite: Intelsat 905 24.5W
Transponder: 11015 MHz
Polarization: Horizontal
Symbol Rate: 7200
FEC: 3/4
Modulation: 8PSK
Standard: DVB-S2
- 4:2:0 FTA
RADIO 1 STAGE
Satellite: ABS 3A 3.0W
Transponder: 11483 MHz
Polarization: Vertical
Symbol Rate: 10000
FEC: 3/5
Modulation: 8PSK
Standard: DVB-S2
- 4:2:0 FTA
margusten
Lat 59.40 Lon 24.68
DR.HD F15, TBS-5925, Dream 800PVR, GM TripleX
Aerial AS24 polarmount 95E - 13E Ku+C, fixed 3M 28.2E, 27.5W ...
Estonia
Symbol Rate: 7200
FEC: 3/4
Modulation: 8PSK
Standard: DVB-S2
- 4:2:0 FTA
RADIO 1 STAGE
Symbol Rate: 10000
FEC: 3/5
Modulation: 8PSK
Standard: DVB-S2
- 4:2:0 FTA
Actually on 3w there was also Red Button feed near Radio 1 stage feed at night, repeated day highlights.
margusten
Lat 59.40 Lon 24.68
Estonia
At the moment on 3W Red Button Reading feed working again.
Dave5118
Vu+ Uno 4K SE
Edision OS Nino Pro
Sky Q Silver
Nr Manchester UK
I struggle to get 3W most of the time, I assume everybody does, but I get the BBC reading feeds at about 7db on my 1.5m in Manchester. So will will explain you not getting them on your 1.2m if that's the case.
Slight picture break up with the Gibby 100 @ 3 West 11470 V 10000 HD 50% SQ & 11482 V 1000 HD 49% SQ Here in West Essex & raining.
Signals always low from this satellite despite the map advising 60cm dish :-rofl2
Much stronger signals on 24.5 west 11015 H 7200 74% SQ
margusten
Lat 59.40 Lon 24.68
Estonia
What size dish and location?
Location - Estonia Tallinn, near Finland.
First I tried this 3W feed on 1.6M dish, no good results.
Then set up 2.5M antenna to 3W and OK.
There is a few watchable transponders on this satellite.
1.6M white dish has polar mount but 2.5M I have to align manually.
nelson_b
Contributor
Nice dishes ... :)
superpascu2
ATLAS HD100 - ASTRA 19,2 + HOTBIRD 13 + 28,2 1.2m famaval
Alicante
Moving a 2.5M dish manually to catch a feed...jajaja. Cool
stephend2017
KU Band: Motorised 1.2m dish connected to a TBS 6981
KA Band: Eutelsat KA-SAT 9e on Ireland spot beam connected to a TBS 6904
Ireland
That 2.5M is a beast omg
margusten
Lat 59.40 Lon 24.68
Estonia
42E
10962 - Pol: H - SR: 2680 - FEC: 5/6 8PSK DVB-S2 4.2.0
Zeitinli Rock Festival Türkey
margusten
Lat 59.40 Lon 24.68
Estonia
23,5E
Concert
12712 - Pol: V - SR: 9600 (+12726v,7200)
'Nur mit Euch' from Berlin continues
margusten
Lat 59.40 Lon 24.68
Estonia
margusten
Lat 59.40 Lon 24.68
Estonia
At the moment The Cure.
Astra 3A-3B (23.5°E)
Fréquence: 12737 - Pol: V - SR: 7200 - FEC: 3/4 S2 16APSK
Catégorie: Concert
Transmis en: MPEG-4 4:2:2
Infos: Hurricane Festival in Scheeßel
stephend2017
Ireland
Glastonbury is on 3W this year ;(
margusten
Lat 59.40 Lon 24.68
Estonia
