Listen Up Octagon SX88+
stephan94
Bavaria
_1.04.73 is good ( SX88 and SX88+) ;1.04.74 a small number of people have problems with the DISecQ command.
_Update only Internet
1.04.74 a
"Interestingly", yesterday, 1.04.74 was on the Octagon site page for the SX88 (but not the SX88+) and I updated the SX88 (the SX88+ has not arrived yet) to that with an automatic download & install and it seems to be changing sats OK under USALS across the arc.
However, today, 1.04.074 has disappeared, and the latest avaiilable version shown is as 1.04.66 and so not even 1.04.73 (and nothing for the SX88+) - so it looks like the whole of the "1.04.7X" generation has been "canned" until "something" is fixed (I don't know what that is, but would very interested to find out!).
No such problems with the Edision!
boot_sectorz
Sky X2, Beausat 2004 FTA Plus, Echostar LT-730, twinhan Vision Plus DVB Card. 90cm Nokia Dish, 1.8m Also Manhattan 9650 Analogue
Earth......... I hope!
I'm using 1.04.74 on my SX88+ with no problem on the DISecQ and motor. But I had to download the firmware from a third party download site.
I however, can't configure auto-roll in the softcam. Not sure if its the firmware or my own configurations. The rest work perfectly!
FWIW, I can now answer the questions I raised in a couple of posts above:
#290 - the SX88+ (and thus presumably the SX88) does transmit both DiSEqC 1.1 and USALS commands at the "same time"(consecutively, I presume) if both settings are enabled.
#295 - the combo of the Spaun relay and the RF-remotely controlled 12V supply for it works fine. The relay switches between the steerable TD88 and the fixed dishes with LNBs connected to the DiSEqC 1.1 10-1 Opticum switch down the garden, and thus I can connect to (say 13E) via either route simply by clicking the RF remote control switch button, with no need to go into the SX88+ menus to make any changes - "Simples" :)
PS: the RF remote is stuck to the underside of the SX88+ remote with d/s tape, and it has a sliding cover over the button to prevent accidental changes from the switched LNBs to the steerable dish.
antenutze
multi-satellite antenna
belgium
Hi, does anyone knows what brand it's the tuner of Octagon SX88+ ? (SiLab, Samsung, BCM,...) or what Cipset have the tuner inside of the metalic box
Tks
t1-jpg.120805
@jeallen01, you know the answer or you only know where I must post it
I took a SX88 apart to see if there was any id on the tuner but like the post above no id ?
antenutze
belgium
and the tuner is.... that is the question :confused if you have possibility to see inside the metalic box of tuner and we have the tuner CIP ID we'll know the answer
FWIW (which is not a lot!), just been trying to sort out another fixed dish on 52-53E (with no great success so far), and then, to check whether 53E (Express AM^) was still actually receivable here ATM, I ran some tests from the indoor "office" with the TD110 and - in order - the TM5402M3, SX88 (not the "+") and the Free Sat 7HD (the dirt cheap "fag packet"!) on 53E and a couple more weak sats.
The results were somewhat surprising, especially after the signals began to drop from around 17.00 GMT: the FreeSat managed to get a half-viewable picture and the TM was noticeably worse - but the SX88 couldn't get a signal on any of the main receivable 53E transponder 12594V 2700; not a bloody thing even at the slightly earlier time when the TM was showing a pixellating but viewable image on most channels!:rolleyes:
EnoSat
enosat.euweb.cz
Slovakia
Tks
t1-jpg.120805
Tuner IC RDA5815m - RDA Microelectronics, Inc. RDA5815-Fully Integrated Satellite receiver for DVB-S , DVB-S2 & ABS-S,MMDS
RustySpoons
Sleepy Hollow
50E - 30W
2x CM 1.2m Polar Mount/Jack
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
AndyX
Scotland
TM-F3/5
Octagon SF4800
Octagon SX88
Fibo Gregorian 1.2m
Motec Positioner
Inverto c120 twin LNB
Central Scotland
Catch up TV now excellent :):Y
