Satlink WS6906 and thor .08
jimbo2911
vu+ duo
cheshire uk
Hi All do any of you have a image file with a program list for Thor at .08 west i just cannot find it and i have clear sky to south
my thinking is if a had a image with all fta channels if would be easy to find
thanks Jim for any help
jimbo2911
vu+ duo
cheshire uk
What could do with is a image with one or two channels on 28.2e 26.0e 19.0e 13.03 and 0.08w to set my arc right as my sig/tone meter does not give what sat it is picking up and if i had that image atleast i would see a picture on what i had found
cheers jim
jimbo2911
vu+ duo
cheshire uk
hes what i have up to now makes it a bit easier to find sats when you hear a tone on satmeter 28.2 26.0e 0.08w with a few channels on each sat
cheers jim
  • bin.zip
Have you asked your supplier for a list ?
jimbo2911
vu+ duo
cheshire uk
no but it ok i will sort it now i found 08w lol i put a spare dish on ground and just left right up down till i found a signal then clicked on scan till i found 08w as the dish is abt 10ft off ground it was a lot safer now i can connect it up to 6906 and turn it till a channel appears
when i have most east to west sats i will redo bin file and post it
cheers Jim
