el bandido
- Feb 25, 2009
- Age
- 61
1.2 meter KU band
3.6 meter C band
Enigma2 Receivers
- Atlanta, Ga. USA
The Satdream patch is nothing to do with the plugin. It is in scan.cpp in enigma.Does it contain the blind scan fix that Satdream implemented?
As you can tell, not good with things E2, but I'm learning....Thanks for the info!The Satdream patch is nothing to do with the plugin. It is in scan.cpp in enigma.
The Satdream patch to scan.cpp and the patch to the plugin will both be in that OpenViX image as it was built in the last few hours.
Actually I forgot to push the scan.cpp patch, so it will be in the next build.As you can tell, not good with things E2, but I'm learning....Thanks for the info!
I have had a little bit of time to run the OpenVix image. I find the performance of the scans and resolving transponders to be about equal between SatDreamGr and OpenVix images. I think any image that allows you to watch tv on the channels you want is a good image, and I appreciate ALL of the work that is put into making the different images and the Skins.
Attached are two screencaps showing a blindscan of 113W C band. This satellite has a variety of transponders, but most are small symbol rates with several being 2000 or less. This is a very good satellite for testing the capabilities of fta equipment. The Nino Pro loaded with OpenVix image found 40 transponders on this satellite. The total scan time was around 6 minutes which means that a transponder was found and processed about every 9 seconds on average. This is very good for this satellite!
View attachment 120574 View attachment 120575
The only thing that can explain this are the changes in the tolerance setting I made yesterday to the plugin .I agree, I also have been testing, and a scan of 40W C Band the OpenVix gave me another 6 transponders over the Satdream, I also could not install IPK files off a USB with Satdream but OpenVix is fine.
No feeds found with the extra transponders, but some come in better at night when I did the scan so that also could explain it. Think I will compare with the SF8008 and see..Good morning
On this satellite there are often feeds, it can also explain the difference.
To be certain of the best result we would have to compare the list of transponders between the two images.
SatDreamGr has a slight transponder advantage right now only because the 2 MHz spacing is not in OpenVix yet. This advantage disappears in the next OpenVix update. Other than closed spaced transponders in MHz, both images should return the same transponder count on scans.I agree, I also have been testing, and a scan of 40W C Band the OpenVix gave me another 6 transponders over the Satdream, I also could not install IPK files off a USB with Satdream but OpenVix is fine.
They did indeed return the same transponder count on 40W C band, or rather the SF8008 with Open ATV and the Nino with Openvix did..SatDreamGr has a slight transponder advantage right now only because the 2 MHz spacing is not in OpenVix yet. This advantage disappears in the next OpenVix update. Other than closed spaced transponders in MHz, both images should return the same transponder count on scans.
Yes agreed StephenBut the result of the Edision OS nino pro is much more precise in its data (DVB-s2 is indicated as well as the MIS 171) View attachment 120585
the 8008 does not indicate anything.
It actually says both: L and R and V and H.The El Nino is indicating Left circular polarised signals as Horizontal linear polarised signals, this is not accurate. The SF8008 correctly recognises the circular polarity. Is this issue a setting in the satellites.xml file or some other configuration setting? The El Nino needs to correctly report circular and linear polarity before it can be considered precise.
It would have been necessary before completely removing the satellites.xml of "ninoPro "to know what it indicates of itselfView attachment 120586
