New Edision OS nino Pro Grey 1x DVB-S2X + 1x DVB-C/T2 Linux Enigma 2 Combo Tuner Digital Multi-Stream Receiver H.265 HEVC HD 1080p
stephan94
Bavaria
Hi MCelliotG
I always want to check for myself what is announced.
Sometimes what is written is very good, but unfortunately has little to do with reality.
Confirmed changes to Ka etc in Blindscan are working in the SDG image on the Nino Pro. I have this receiver on Multiboot nowBS1.jpgBS2.jpg
I tried the C band in blindscan (40 ° East), all the frequencies were found.
It was necessary to make a "restart" so that it finds the programs on all these frequencies, unfortunately there is no image.
With OpenVIX version 5 2 011 we could see a fuzzy picture, but with the new versions the screen stays black.
I did not look elsewhere for the T2MI.
On the 40 ° East it's really special, because they are T2MI on Multistreams.
Perhaps the difficulty comes from there.
I'm only working with OpenVIX. View attachment 120771
Can you guys get us some full transport stream recordings from 40 east if I give you some instructions. This would go a long way to help getting these FTA channels to display on enigma hardware.
Sure, if it's not beyond a simpleton like me!
stephan94
Bavaria
Blindscan abilities of this receiver are amazing. It is going to become a legend. People will still be talking about it in 10 years.
And thanks to Scopus, Stephan94, and elbandido for providing help getting blindscan Ka-band working.
Many thanks to all contributors and well done for all of your work on the blind scan, it will be appreciated by a lot of people.
Am I correct in thinking that the daily overnight VIX build is up to date with the most recent changes that have been coded for the blind scan and any other functionality? Or is it several days before any changes you code are integrated into the VIX image?
Does it now deal with T2MI transponders OK?
el bandido
1.2 meter KU band
3.6 meter C band
Enigma2 Receivers
Atlanta, Ga. USA
OpenVix does not normally have daily or overnight builds that are available to the public. The images that do have daily or nightly builds can introduce problems into a receiver that can be difficult to fix. OpenVix has testers that check the image and look for problems Before it is released to the public. It is about impossible to have the image checked properly when it is built daily or nightly.
Thank you for the information re the build and rollout status of the OpenViX image.
One more question if anyone can please help, does the latest stable and tested OpenVIX image dated 28th November 2018 include the recent blind scan coding work by "Huevos" for the Nino Pro (v 5.2.0.15)?
stephan94
Bavaria
Hello, just a quick question:
I do not know how to have the same display as on the screenshot of huevos.
On my image they are words, on the other it is with a button that we can put on red or green.
It is likely very simple, but I did not find.
thank you in advance for explaining to me how to do it.
Stephen its in the GUI settings not in front of the receiver right now but its at the bottom of a long settings menu called 'show slider instead of true or false'
@Captain Jack
It supports and displays T2MI but not multi PLP at the moment. So T2MI 40 east transport streams currently not possible.
Edision are aware of this. No idea if a fix will be provided, but at the current time no enigma2 receiver can deal with this type of transport stream natively.
stephan94
Bavaria
Thank you very much.:)
I finally succeeded.:Y
