40.5W SES6 & NSS806
I forgot to include the EBS Pro signal analyser screen grab for the 40.5W transponder (3980 L, SR21600) in post 71, now attached below.
Got lock now and a usable picture on the Hellobox. LNB has been changed to the Titanium Wideband version and a bit of careful tweaking, at leat today has been dry here...
@scopus
Well done with that lock, I think the Titanium LNB has the edge over the Zinwell in them polo pipes, just enough to get a lock on it. Thats a good result with a 1.8m dish to lock that one.
@scopus
Yes the C band LNB is also offset from focus too, They ain'y bad these Famaval dishes...
antrabe
dreambox7080 dm900 viark droi
spain
Hello at the end i installed my dish 1.8m to get 40.5W 5-5W and 58W i can get 55.5W almos 200 channels and all transponders but i cant get as well the 40.5w getting 50 channels only i have lnb ainwell 15K and im thinking to buy titanium lnb to check if i improve.
somebody test both lnbs?
I tested both the Zinwell and the Titanium LNB's in a polo pipe and found that the Titanium performed better. I could not get a lock on 3980 L on 40.5W with the Zinwell LNB but the Titanium LNB locks it easy. Also for both these LNB with only the dielectric plate and no polo pipe I found that the Titanium LNB was better.
antrabe
spain
ok perfect thanks i already order the titanium to check i suppouse that the frec that i cant lock its due to some signals that disturb and wth the filters that titanium has maybe is solved. let see ...
Although zinwell is 67db gain adn titanium 65db. ill check in 2 weeks when i receive the new lnb
thanks
PrvtN00b
2.4 PF, 1.8 Raven Offset and 1.2 offset for DTV
Panama Central America
but where are you located??? I'm from Panama and I can get 220 Channels from the 40.5w with a C/ku LNB I think is a Titanium one
If your question was addressed to me, I am located in the UK.
antrabe
spain
Today by surprise i found that turn the lnb horizontal the dielectric reach 205 channels almost all i think 1.8m from south of spain,
I already order the titanium i think could be better even with 65db gain against 67db zinwell.
let see when i receive it
The Edision Nino Pro receiver also managed to lock the ESPN Brazil transponder of 3980L from 40.5W in C band. The SNR at 8.8 db from the Nino Pro was not quite as high as the 9.1db I achieved with an EBS Pro scan last week but the signal seems to fluctuate.
I have attached a few pictures below taken from the Nino Pro running an OpenVIX image.
NinoPro_20181212_40.5W_3980L_01.jpgNinoPro_20181212_40.5W_3980L_02.jpgNinoPro_20181212_40.5W_3980L_03.jpg
Lexzie
TBS 5925 USB-tuner
The Netherlands
@moonbase You did that with a 125 cm dish?
No, it was a 2.0m dish as indicated by "scopus" in his post above. It is only a temporary dish installation for a few weeks on a mobile platform so I did not update my forum profile.
Further tweaking had got me solid lock now on this mux with a steady 8.1dB. LNB is offset and using a 1.8 dish in the MidlandsESPN Lock.jpgP1010028.JPG
PrvtN00b
this sat has some BBC mux there using IDERTO, I'm wondering if is possible to open it using an Enigma 2 Box...
Further tweaking had got me solid lock now on this mux with a steady 8.1dB. LNB is offset and using a 1.8 dish in the Midlands...
That is a nice result with a 1.8m dish, especially with the LNB offset from the centre focus.
OK on the nino, I think the tuner is slighlty more sensitive on the Hellobox...Nino ESPN.jpg
@scopus
Nice one, thats a good lock at 8.3db with a 1.8m dish for ESPN Brazil. It looks like you have got the Nino Pro correctly configured and running smoothly with E2, well done.
Was the signal level of 8.3db obtained with the Titanium LNB in the polo pipe? It might be interesting to see what signal level you get if you did a direct swap over from the Titanium to the Zinwell on the El Nino? My guess is that the signal level would drop using the Zinwell?
@scopus
Yes MB it's the Titanium and the polo pipe. I have tried many times to get this mux with the Zinwell, but it's having none of it!
This is a new Titanuim LNB, I have tried these in the past but not been too impressed, whether they have tweaked something in this newer version I don't know...
otokoc
DM920HD
prodelin1244
Balikesir,Turkey
hi i need espn brazil for oscam.conf files.
