Nc+
stonesatellite
Vu+ Duo 4K SE (2x DVB-S2X) (2x Xbox One USB tuners (1x DVB-C & 1x DVB-T2) (1x Nooelec NESDR Nano 2+ USB RTL-SDR tuner)
Octagon SF8008 (2x DVB-S2X)
Mut@nt HD51 (2x 2x DVB-S2X)
Triax TD110
Sky zone 1 minidish
Inverto Black Ultra Twin LNB
Alsat Superior Dark Motor
Onkyo TX-SR605
6x Bose Acoustimass/Lifestyle double speakers
Stone, Staffordshire
brought an official NC+ subscription & Conax cam however the channels arent clearing & all the seller keeps saying is NC+ say its active, to rung NC+ if i dont believe them (iv asked for NC+'s number but the seller hasnt given it me) & that my receiver must be faulty (iv used other cams with it before & never had any problems) iv sent the seller pictures that show nothing is clearing, not sure what othet proof they need. iv asked them to get the activation signal resent but they wont accept theres a problem & so wont get it resent. what whould i do here find someone from Poland to help me, open a Paypal dispute ? i ordered it in 19th & it came on 22nd so should be active by now.
What happens when you press OK for subscription status ?
Is it from one of the forum sponsors, (past or present ) ?
Have you tried the card / cam on a completely different system ?
stonesatellite
Triax TD110
Sky zone 1 minidish
Onkyo TX-SR605
it just shows the same page that i took a picture of.
not sure, was from eBay but wasnt the current sponsor. i did check their feedback before tho.
yes iv tried the card in two other recievers one using the cam & the other an official NC+ Nbox 5800S & is exactly the same messages in the Comman Interface menu & nothing clears.
It looks from the image that the card was activated in July 2013 and was renewed for a second month. March 2013 was the first year of satellite broadcast so unless I'm mistaken the card has been around for almost six years
stonesatellite
Triax TD110
Sky zone 1 minidish
Onkyo TX-SR605
thats what i thought, what would you suggest i do ? as the seller is less then helpfull
Topper
Amo Amas Amant Admin
Blackburn, Lancashire
If you paid by Paypal then open a dispute with them and show them the evidence of the age of the subscription, that should be enough
There is a small chance you have an older style of Conax cam that will not allow the update to occur, which version is on the sticker ?
stonesatellite
Triax TD110
Sky zone 1 minidish
Onkyo TX-SR605
its one of these Smit Conax Hardware Version: 5.1.5.2 CIM Build Date: Oct 20 2017
stonesatellite
Triax TD110
Sky zone 1 minidish
Onkyo TX-SR605
ok will do thank you
Topper
stonesatellite
Triax TD110
Sky zone 1 minidish
Onkyo TX-SR605
Before you do check the original advert to ensure that the wording stated it was a valid subscription
yes i have & it does.
thanks
mike1
Non-28.2° Sat Specialist
Yorkshire Television
Triax 64cm triax ( Darkmotor ) Inverto Black Ultra.
T55 - 28E/19E/13E/1.9E
Mutant AX 51 Open PLi
GT Media V7SX
Next time buy the nc card with RSA key. So no need for CI module. The rsa key goes in oscam via web interface. I can post more info if required..
I find Engima 2 not great with handling Common Interface modules.
stonesatellite
Triax TD110
Sky zone 1 minidish
Onkyo TX-SR605
never had a problem before with CI modules & Enigma 2. from what iv read online a few people have needed to get the activation signal resent but this seller wont help or even except theres a problem
Be careful with CI CAMs. Not all receivers are CI+ compatible, though most Enigma2 ones have plugins to make them work - albeit unofficially.
stonesatellite
Triax TD110
Sky zone 1 minidish
Onkyo TX-SR605
im using a Mutant HD51 which is meant to be CI+ compatible
It is....with the right plugin.
stonesatellite
Triax TD110
Sky zone 1 minidish
Onkyo TX-SR605
Yep, that's the one.
stonesatellite
Triax TD110
Sky zone 1 minidish
Onkyo TX-SR605
I think you need to reboot the box but pretty sure it just worked. Without it, I had an error saying that the CI module was not authorised for use in my receiver.
