C band feeds
Yep, checked an hour after i posted and it had dropped. I,ll stay parked up on it and check it out again today. Nothing there at the moment (8.55am UK)
This new freq now up again now at 6.20pm UK, also with another new one at 3847 LHC. Too low for a lock with me. Any takers.
Anonymous_1
these contributions are "simply" the main feed for the Dakar 2019
47.5 West, 3817 RHC.
This freq has been documented before on 'Satellitescommunity.de but today is displaying as this on the analyser. ( all part of same signal ).
.. Now same thing down at 3718 RHC
Anonymous_1
I think there is a problem with your scan or polarization, because 3817 R is in the mioddle of the both mux on 3804 & 3835
for 3718 RHCP, this is a continuous stream
Attach files
PS: the 3 main Dakar Main feeds are active in LHCP
Anonymous_1
Laax Open 2019 (SVC1) 5°W 4060 R 6666 3/4 (new paramaters since AFP has left EBU mux worldwide, long story...)
Help needed on this one - - I think it's on 45 West but not sure. Low level signal with me here.
3903 H. 1410. 3/4. "Revival Channel"
Still need this confirming by anybody else, it's still up and running and suspected coming off 45West - Europe/Africa beam.
What would make this channel come through on a 'non inverted' spectrum setting on your kit ?
If you have it on TV again watch the blue banner scroll at the bottom of the screen, the clue might be in there. It is definitely the Revival Channel from Cameroon as the 16E Ku band parameters in the blue banner strip check out OK. However, the Intelsat details are just off screen to the right in the blue banner.
Good call MB :Y ...... checked the scrolling banner out and eventually after a while the info came along. Shows it on 16 East and also Intelsat 14 @ 45 West on the freq i quoted but the banner info says 'Vertical' where i am in Hor mode on my lnb ?.
.........................................................................................................................................................................................................................................................................................................Revival Channel - info..... reduced .......JPGRevival Channel - info..... reduced ...JPG
Anonymous_1
Yes John, confirmed the correct polarization is H
in V there is a new empty stream (future DATA of channel)
47W Cricket Highlights feeds (West Indies v England) just gone off air as I type...P1010036.JPG
Mixed Martial Arts - - 55 West. 3939 V.
