Best enigma2 receiver 2019
stuzeeuk
Dont eat yellow snow
Triax 88, mulitblock
13E, 19E, 28E
DM 800HD
Glasgow, Scotland
Guys,
I am looking to buy a reasonably price receiver for UK cable, 28E, 16E and 19E. What combo box do you think is best?
I was thinking OCTAGON SF8008 or Edision OS mio. I really need something with a decent DVB-C tuner. I previously have a Vu+ Solo2 with a USB DVB-C tuner, it was great when I only used it for satellite. However, it was continually crashing and in the end I offloaded it.
OCTAGON SF8008 4K UHD Linux Enigma 2 2160p H.265 HEVC Dual Wifi Multi-Stream DVB-S2X & DVB-C/T2 Combo Receiver
Edision OS mio 4K UHD Grey 1x DVB-S2X + 1x DVB-C/T2 Linux Enigma 2 Combo Tuner Digital Multi-Stream Receiver H.265 HEVC UHD PVR
Any views would be much appreciated.
shriarun
Hotbirds ..eutelsat9.. Arabsat..Yahsat..Asiasat..Insat2e..Intelsat..Measat
india
for me zgemma h9 twin is the best stb in the year 2019....the best Linux stb PRICE range wise...above all in this range no other LInux and multi operting stb... HEVC 4K...quadcore processor...dual wifi antenna...Tuner is really awesome which must be a quality of a stb...hyper sensitivity of its tuner makes it a master box...it is really a gift for all those sat trackers who are fond of tracking out of coverage satellites...recommended....
LeBelge
2x Triax TD 110, 2x Edision OS Mio 4K (plus), Edision OS Mini 4K, Edision OS Nino Pro
Belguim
There is no blind scan with Opena.tv 6.3
My Mio 4K does not show any signal level for DVB-T2 channels from Germany and France (DVB-T), but finds them all. Some of them are very weak and I use an amplifier. For the belgian (DVB-T) channels I see the correct level before scanning.
I use toys like this one:
LeBelge
Belguim
For satellite channels you have to download a plugin outside the official openatv's repository, but it is easy to find and comes with very good list of ... you know what, don't you ;)
It seems to have auto update that works fine so far.
Laser
I have a MIO 4K. Can you tell me the name of the plugin please. Thank you
Does this box do T2-MI transponders natively (without astra-sm)?
dmaavrigdo
1.2m Laminas OFC1200 dish
Inverto Quad Black Ultra IDLT-QDL412-ULTRA-OPN
Octagon SF8008 twin
Yamaha HTR-2067
Vansbro Sweden
Inspired by this post I acquired an H9S and am quite pleased except for one thing. If I try to set it to 2160p and auto resolution disabled the screen goes blank and my AV unit reports "decoder off". After a while it sets itself back to 1080i and the picture returns.
I can see the 4K demos in 2160p if i use auto resolution but don't like the consequent long delays on channel change.
Am I not allowed to set 2160p permanently?
shriarun
india
it might be cause of your tv isnt supporting 2160 resolution....i m using sony smart tv with this stb no as such issue....i will again recommend this stb...my best ever experince of this stb
dmaavrigdo
Octagon SF8008 twin
Yamaha HTR-2067
Vansbro Sweden
As I mentioned above my TV does support 2160 24Hz, 25Hz, 30Hz,50Hz,60Hz
. Further research today suggests that I might have to set a lower fps than the 50/60 hz available on the menu possibly because of my AV amp.
This is what I found "Forcing the mode using "echo 2160p25 > /proc/stb/video/videomode" works and I can confirm the t.v has switched resolution and is displaying fine,"
Edit. I think I'm on the right track. Now watching the 4K demo at 2160 24HZ. Just have to find the right settings to retain control.
Strange, the AV amp isn't in your profile.
What brand / model is it ?
dmaavrigdo
Octagon SF8008 twin
Yamaha HTR-2067
Vansbro Sweden
It was never important before.
Yamaha HTR-2067
Checked the specs and there we are "- 4K/30 Hz, 25 Hz, 24 Hz"
