multistream Sky TG24 mux on Eutelsat 33E
stonesatellite
Vu+ Duo 4K SE (2x DVB-S2X) (2x Xbox One USB tuners (1x DVB-C & 1x DVB-T2) (1x Nooelec NESDR Nano 2+ USB RTL-SDR tuner)
Octagon SF8008 (2x DVB-S2X)
Mut@nt HD51 (2x 2x DVB-S2X)
Triax TD110
Sky zone 1 minidish
Inverto Black Ultra Twin LNB
Alsat Superior Dark Motor
Onkyo TX-SR605
6x Bose Acoustimass/Lifestyle double speakers
Stone, Staffordshire
have tried to scan this Sky TG24 mux listed on Flysat FlySat Eutelsat 33E @ 33.1° East what do i select for dualstream & where/how do i enter TX1 MI & TX2 MI 97 on Mutant HD51 or is this a no go ?
You'll find both streams-TX1 MI & TX2 MI 97 if you scan twice.
stonesatellite
Triax TD110
Sky zone 1 minidish
Onkyo TX-SR605
hi thanks for you reply, still nothing. not sure what transport stream type, ID & mode etc to use ? tried doing an ordinary scan & says 0 channels found.
thanks
It should be known that our receivers,the commercial ones,although,some,can detect the signal on transponders with generic stream,they can not lock it, and more so to memorize and visualize.I did not succeed with my receivers.Such generic streams are addressed to those who have a dedicated device,a TV program provider.This transponder(12543 V) being an Italian feed.
But if you still want to receive this feed or others but without great hope of seeing it in the clear,you can use Dvbs cards.My pictures above are made with a TBS card and with the help of applications and players we can get information about these types of streams.
Here's what such a picture looks like on a generic stream that you won't get with commercial receivers.
stonesatellite
Triax TD110
Sky zone 1 minidish
Onkyo TX-SR605
thanks i had a feeling that was the case. i may have to invest in a DVBS card. was TG24 HD i was after. i do have the SD version on 5°W tho
I have to make a correction to the above opinion:there are,however,few receivers that can receive this generic stream and even memorize.Among them is Openbox SX6,with which I made a test on this stream.Among them is Openbox SX6,with which I did a test on this stream. Luckily the blindscan found transponder 12543 H,1704,5/6,8PSK and then memorized it. Changing from one stream to another is done automatically without the need for anything else.But that's all he knows.Of course he doesn't know how to play video, as you can see below.
stonesatellite
Triax TD110
Sky zone 1 minidish
Onkyo TX-SR605
thanks for that, really insightful
MCelliotG
Thessaloniki, Greece
If STV chipsets are the only ones that can receive this stream, then a TBS 5925 attached on an E2 receiver will too, and also STi 7111 receivers. I will try later with TBS if I don't forget about it...
Edit: Just checked it!
124444
124443
Looks like E2 (and that's expected) cannot distinguish the dual stream, and downloads the first one with distorted image.
stephan94
Bavaria
It is not surprising that this stream is not seen by commercial receivers;
This is continuous stream only cards (in my case TBS6983) are capable of find by themselves is kind of flow.12543a-vert.jpg
stonesatellite
Triax TD110
Sky zone 1 minidish
Onkyo TX-SR605
i cant even get that at this end, just says 0 channels found
MCelliotG
Exactly, because Silabs can't even see a signal!
sat-tv-fan
East Sussex, South East UK
(66 E) 42 E - 45.0 W
Azbox HD Premium
Azbox ME
Amiko A3 combo (android)
TBS 5925 and 5927 USB
GT Media V8
Octogan SX88+
Octagon SF8008
Koqit K1 mini
Openbox SX6 HD
Mecool K3 pro (android)
X2 Premium HD
Skybox F3
Technomate 5302 HD
Technomate 5402 M3
iSmart X8
Would an Octagon SF8008 get these easily with out all the fuffing about ? Or even my SX88+ ?
sat-tv-fan
Azbox HD Premium
Azbox ME
GT Media V8
Octogan SX88+
Octagon SF8008
Koqit K1 mini
Openbox SX6 HD
X2 Premium HD
Skybox F3
Technomate 5302 HD
Technomate 5402 M3
iSmart X8
Well trying my SX6 although a strong signal I get no video and bad breakup with audio so what is wrong ?
stonesatellite
Triax TD110
Sky zone 1 minidish
Onkyo TX-SR605
hobby receivers cant resolve it sadly
