- Jan 1, 2000
- Location
- North Nottinghamshire.
Update re Badr-6 MENA Beam:
I re-scanned the Badr-6 MENA beam transponders today and obtained improved results compared to my scan of a few months ago. It certainly seems as though the signal level of the Badr-6 MENA beam has increased.
I managed to lock several transponders that I had previously failed to lock, notably 12456H, SR27500 and 12476H SR27500. For anyone in a UK location wishing to try to lock some of the frequencies from the MENA beam of Badr-6 it seems a good time to have a try, just in case the signal levels drop back from their current levels.
Attached below is a small table presenting the Badr-6 MENA beam scan results and a couple of channel pictures. The "Inv C120 Scan 2" column is today's scan result, the column to it's left is the previous scan of several months ago.
@ MB - do us a favour, will you take a snap of the Precision feed you are using on the 2mtr PF when looking at the MENA frequencies - - i'll tell why later.
