Message for rimantss
dreambox1959
46.3N-4.3E-FRANCE
france
hello i have got a AJAK H180 motor with a CM180 , i try to restore it , do you know how to remove the endless screw ?
do i have to cut some welding or piece of steel ?
RimaNTSS
Some SAT-related hardware.
N-E from Riga
Hi! I have no idea. I did not manage to remove it. I think it was assembled and then welded.
I will check the one I have sitting in the shed tomorrow, though I might have to row across the garden to get to it.
I will check the one I have sitting in the shed tomorrow...
That one in your shed would look better on my patio with a dish on it. I got crispy green folding 'ere if you wanna bring it over?
It's welded to something much bigger, a Patriot backplate / canister.
Terryl
Custom built PC
Could there be a couple of roll pins holding it to the shaft? Maybe covered up with paint, or some sort of rust preventive sleeve??
And by the looks of the end it could be pressed onto a spline, the hole at the back of it looks to be a centering point for some lath work, a gear or bearing press may be needed to push it (the shaft) out the one end.
Look at the ends of the internal worm gear, see if there are any splines or key-ways, if so then it's a press fit.
My dinghy has been washed away, so I'm not going to be able to check on the press fit (or other) of the shaft until tomorrow when I fabricate a coracle out of the 3.1m Intelsat dish.
dreambox1959
46.3N-4.3E-FRANCE
france
hi every one who have a CM180 !
what is the value of offset angle of this dish ?
by measurement i have got either 27° or 63° is it right ?
RimaNTSS
N-E from Riga
dreambox1959
46.3N-4.3E-FRANCE
france
i have this polar mount and an ajak 180 but all is unmounted
RimaNTSS
N-E from Riga
dreambox1959
46.3N-4.3E-FRANCE
france
i just want to know the difference between this dish (offset) and a prime focus !
for calculation just use trigonometry!
h1=55 h2 =27 L1(cos1) =55 ====55-27=28(sin1) atan (28/55)= 27°mes2.jpg
a33
Specialised Contributor
XSAT410
Rebox RE-9000
The Netherlands
Or even easier?
sin(angle) = (h1-h2) / L1
so angle = asin ( (h1-h2) / L1 )
(So for angle = 27*, L1 must be 61.7? )
That 27* is declination angle + offset angle, as you wrote.
So you can trust the above value of 22.6 offsetangle; that is calculated by width and hight of the dish.
Greetz,
A33
dreambox1959
46.3N-4.3E-FRANCE
france
i had take better measurements : offset+declinaison is adjustable from 22° to 27° ! (with this polar mount from channel master)
but in france where i live declinaison is about 7° (6.5 to 6.91)
if CM180 is 22° offset : i need 22+7 = 29° minimum ???
RimaNTSS
N-E from Riga
@dreambox1959 CM180 has 22.6* offset angle, take is as axiom. And offset angle can not be changed, it is built-in by manufacture. I think you have drowned in the issue of wrong positioning of the feed. The issue is simple.... CM has made feedarms and LNB-holder in the way that they do not hold the feed (LNB ) in proper position and not properly point it towards the surface of the dish.
And when we add the polar-mount to the system whish is already has too many mistakes then we finish with totally messed-up construction.
My advice to you would be: make sure the feed is placed and pointed correctly and then start to adjust the polar-mount.
dreambox1959
46.3N-4.3E-FRANCE
france
thanks rimantss this dish was a gift from a english guy who live in france but the mount is rusted , the whole dish is correct i have arms (lnb holder) for ku and C (2 set of arms) and 2 feedhorn especialy a big one for C-band.
these days i build a new polar mount based on AJAK-h-180 i ll post some pictures soon.
RimaNTSS
N-E from Riga
@dreambox1959 congratulations, you've got one of the best dishes possible. As far as I know CM did not make LNB-holder for C-band LNB. Could you, please show some pictures of the hardware you have?
dreambox1959
46.3N-4.3E-FRANCE
france
just in case lnb arms don t came from channel master , what is length of original arms ?
i got the dish with this feed :
